I just had Exotic Muscle longtubes installed and there is one problem: on the passenger side, one of the primaries is touching a part of the frame, maybe a foot from the start of the tube. It's rattling like crazy!
I tried stuffing a piece of titanium exhaust wrap between the tube and frame but it just fell out. Next I'm going to buy a coolant hose and cut that up and try to jam it in there, but I fear it could melt/catch fire. Any fixes that don't require removing the headers?
Ox/acc torch and heat up the header and bend it so it doesn't touch.
That's what I was thinking, but the headers are ceramic coated, will the torch crack the coating?
Originally Posted by bjankuski
Stand on it (Floor it) in foward or reverse, it will dent the pipe it to where it is happy and quit rattleing. It may sound hack, but I am serious.
That does sound very hack haha but I'd still try. The problem is that it's BARELY touching, so little that all it does is rattle due to the on-and-off contact with the frame. It's so annoying it's driving me nuts!
I've seen a few that have notched the frame. I was lucky, mine fit without interference.
I think grinding down the frame or getting a torch to the headers are the only long-term options. To grind the frame I'd definitely need the headers out, I might be able to get a torch in there while they're still attached.
Simple, done this a couple of times with my cars. With the headers hot, place a tire iron (or large screwdriver if you have minimal clearance between the header and the frame. Torque the tire iron one way or the other. The header will bend slightly and the primary might flatten a bit. You will have the clearance you need.
Well that sounds simple enough, I'll give that a shot. Will normal driving be able to get the headers that hot though? I'm going to autocross this weekend so I could try it after a couple of runs if necessary.
Just idling in the garage for a couple of minutes will be fine.
I just tried it using a massive screwdriver and a crowbar. It actually worked a LITTLE bit, but the noise is still there when I make a left turn (it doesn't do it in a straight line anymore though). I'm going to give it another shot at autocross when it's really hot.
Originally Posted by dgantt
I just had the same headers put on mine two weeks ago and they too are makeing a bit of a noise, I have not started digging around to much yet.
Is one of the primaries contacting the frame on the pass side? That's where mine is rattling from. You can tell where it's coming from by turning; it's on the right side if it rattles louder when you turn left.
