WTF am I doing wrong
Old Jun 24, 2002 | 10:49 PM
72tccracer's Avatar
72tccracer
Default WTF am I doing wrong
Okat to make a long story short I have tried everything that I have read on the board to burn a chip.
The last thing that I did is read the bin file out of a chip that my car runs on and put it into another memcal. Both memcals have 27c128 eproms. The program loads the eprom without an error and verifies it, when I stick the new memcal in the computer the car runs, but the service engine light is on and I can't link the Diacom up. I am assuming it is running on the base cal from GM.
The car is an 86 and has the 165 computer.
Please help.
Chuck http://www.tccracing.com
#72
Old Jun 24, 2002 | 11:46 PM
HighHopes85's Avatar
HighHopes85
Default Re: WTF am I doing wrong (72tccracer)
And your fans come on too, correct? First, did you erase the second chip before you programmed over it? (I know it verified, but I won't even start to tell you some weird things I have gotten PP to do ;) )
Second, what is the second MEMCAL from? On my 90 setup with a V8, I had tried to use a V6 MEMCAL for a while. Turns out that there is some cylinder select on the MEMCAL itself, so I couldn't get the car to run, Diacom to connect, and I just had my fans running with the 'Your engine hate you' light on.
Good luck. -Matt-
Old Jun 25, 2002 | 12:45 AM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
Chuck,
Send me the bin file and I'll look at it for you. My email is ourflat@jccomp.com. If your file is bad then we'll get you a good bin file.
Frank
L383 Powerhouse Blown
Ed Wright Chip Trashed; Home Grown with a little help from DIACOM GM PLUS and AFR
Old Jun 25, 2002 | 07:33 PM
72tccracer's Avatar
72tccracer
Default Re: WTF am I doing wrong (Corvette86)
Okay I'll buy that it is a differnt memcal, it was in a computer that was laying around our shop. How do you tell the diff?
Chuck
To WTF am I doing wrong
