Coolant leak.. Need some help please
Old Jun 11, 2013 | 09:36 PM
cypher85's Avatar
cypher85
Default Coolant leak.. Need some help please
My car has a static coolant leak coming from the bottom front of the engine. I cannot see anything coming from the water pump.. or anything by viewing from the top of the motor. When the car is on it leaks faster. The water pump is 2 years old and the motor was rebuilt last year. I really don't think it is coming from the water pump. I am driving a 1990 zf6 383 stroker. I wish there was more info I could give, I have uploaded a picture from it leaking with the car off.
[IMG][/IMG]
Old Jun 11, 2013 | 09:59 PM
Corvette40's Avatar
Corvette40
The water pump weep hole is on the top of the pump and behind the pulley, you cant see it. I had a supporting vendor here rebuild my water pump, which was leaking from the weep hole, while they had my car for some other work and a year later it failed again. I bought a new pump from Autozone and 4 years later its still good. Its hit and miss with new and rebuilt parts.
Old Jun 11, 2013 | 10:06 PM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
From the picture I would have to guess the water pump area maybe not the weep hole maybe a gasket, run your hand under the weep hole from the top of the motor and see if its wet there. My first AC DELCO water pump only lasted one season, so it can happen.
Old Jun 11, 2013 | 10:26 PM
cypher85's Avatar
cypher85
I guess it may be a gasket.. the peep hole is dry. When reaching underneath the water pump I don't feel any wetness either soo.. I don't know.
Old Jun 11, 2013 | 11:13 PM
don hall's Avatar
don hall
Any reason not to pressurize the system to find the leak?
You post that "when the car is on, it leaks faster". That is due
to pressure in the cooling system. Many radiator shops will
perform the test for free.
Old Jun 12, 2013 | 12:37 AM
cypher85's Avatar
cypher85
No reason not too. I was just saying that it has a static leak as well. I guess I could look up a shop around town to run the test.
Old Jun 12, 2013 | 11:43 AM
don hall's Avatar
don hall
You can add coolant dye to help locate the leak source.
Not recommending this product, just alerting you that a product exists:
http://www.oreillyauto.com/site/c/de...rd=coolant+dye
Old Jun 12, 2013 | 12:22 PM
desertmike1's Avatar
desertmike1
Guessing Game at best..
You ned to get in there with a mirror and find the dam thing, or at least provide more info..
Old Jun 13, 2013 | 12:45 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
It might be the hose to the water-oil cooler. Check there first.
Old Jun 13, 2013 | 08:40 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
+1. You can discuss this problem on the forum for months but the bottom line is you need to find the leak. Anything here is pure speculation.
Old Jun 13, 2013 | 09:57 AM
RWDsmoke's Avatar
RWDsmoke
Many auto parts stores have loaner tools. One of those tools is a cooling system pressure tester. Even a very small leak will show up under pressure.
To Coolant leak.. Need some help please
