Need some help with interior repairs
Old Jun 12, 2013 | 03:16 PM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
Default Need some help with interior repairs
Car is a 1989 Corvette Coupe
I have almost everything redone on the car and I am about to start the painting process in a couple of days. I only have a few things left to do and i'm sure I could figure it out myself but why not ask other more experienced member that have probably done the same things multiple times.
First off my dash has a pretty good sized crack in the middle of it only in the top portion and not all the way through. I was wondering if anyone had any advice on how to fix this as in some type of bonding filler or putty that will stick into place and can be painted over to be a new looking black again.
Another thing is some of the plastic trim has some cracks around the screw holes and I was wondering what I could use to fix the cracks on those also. So that I can repaint them and make them look new again until I can afford some new ones.
That is all I can think of for now that needs to be done if I think of anything else I will update the thread.
Any and all help is appreciated and any advice is also greatly appreciated.
Thanks, Stephen
Old Jun 12, 2013 | 03:49 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Stephen, in the future be sure to list the year of your C4 as the later models are much different than the earlier ones. Looks like yours is an 89.
Try this for the dash pad:
http://www.corvetteamerica.com/cf/di...word%3A%20dash
And this for the cracked dash panel. Used ones are very difficult to find cause most of them are cracked at the screw holes:
Old Jun 12, 2013 | 03:57 PM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
My bad, I normally put it in the title of all my post and seem to have forgotten but I have corrected it in the post.
I was thinking about the dash cap I was just not sure how it would look ontop of the old dash as I am kind of a picky person. Also I do not have loads of money and was hoping for a simple, or hard if it has to be, repair.
I'll keep what you posted bookmarked and if no one else knows how to fix it or I can't find a way then that will be my option.
Thanks, Stephen
Old Jun 12, 2013 | 05:07 PM
tunedport85inject's Avatar
tunedport85inject
this is the stuff you'r searching for...use it on the cracked bolts holes
Old Jun 12, 2013 | 05:57 PM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
Plastex plastic repair kit - YouTube
Thanks, I'll try to order some soon and see how well it works. It looks like it should work excellently
Old Jun 12, 2013 | 06:02 PM
tunedport85inject
Old Jun 12, 2013 | 06:05 PM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
Yep, I think in a little while i'm gonna go to autozone and some other local places and see if I can find any fillers to fill the crack in my dash cause it really annoys me haha
To Need some help with interior repairs
