DFCO Disable RPM Threshold
Old Jun 13, 2013 | 08:57 AM
93 ragtop's Avatar
93 ragtop
Default DFCO Disable RPM Threshold
In tunerpro RT is this the rev limiter?
Old Jun 13, 2013 | 09:02 AM
JackDidley's Avatar
JackDidley
DFCO is decel fuel cut off. Not a rev limiter.
Old Jun 13, 2013 | 09:43 AM
93 ragtop's Avatar
93 ragtop
Jack, could you tell me where the rev limiter is located in tunerpro rt?
Old Jun 13, 2013 | 01:54 PM
bjankuski's Avatar
bjankuski
It is under scalers.
Old Jun 13, 2013 | 05:20 PM
93 ragtop's Avatar
93 ragtop
I just don't see it. But I am having problems getting my bin dif. loaded. I loaded a 92 (I have a 93) I posted about that as well. But thanks for your help.
Old Jun 14, 2013 | 01:45 AM
Cliff Harris's Avatar
Cliff Harris
I'm curious to know if the rev limiter is enabled in later C4s.
My '86 EPROM has the rev limiter set to 10031 RPM. The first time I calculated that I thought I made a mistake, but that's the correct number. Basically the rev limiter is disabled because it can't possibly reach that number.
Old Jun 14, 2013 | 07:40 AM
JackDidley's Avatar
JackDidley
93 Rag, go to the gearheadefi forum and download the xdf for a 93. There is a 92 xdf on the internet that is very incomplete. Its probably the one you have. LT1 cars normally have the rev limiter in use.
Old Jun 14, 2013 | 11:44 AM
bjankuski's Avatar
bjankuski
[IMG][/IMG]
To DFCO Disable RPM Threshold
