Where to find missing A/C component
Old Jun 13, 2013 | 11:04 PM
Atl_monte's Avatar
Atl_monte
Default Where to find missing A/C component
Just purchased a new A/C compressor to replace the missing compressor on my 1992 Corvette, the new unit came without the manifold on the compressor and sicne I didnt have the original I wasnt able to remove it and install it on the new unit, now I'm wondering where I can find the just the manifold for the new unit.
Old Jun 13, 2013 | 11:11 PM
don hall's Avatar
don hall
Corvette salvage yard?
Old Jun 14, 2013 | 05:17 AM
87bob's Avatar
87bob
Veteran: Coast Guard
If you do an Internet search you may find one as I recall people like Vintage air have them. Check old air products under compressor accessories they show several.
Old Jun 14, 2013 | 07:49 AM
Atl_monte's Avatar
Atl_monte
what would be the proper name for this component? part #??
Old Jun 14, 2013 | 08:45 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Try Paragon also.
Old Jun 14, 2013 | 09:03 AM
WVZR-1's Avatar
WVZR-1
I'd say your "manifold" is correct and while you're getting one of those you'll need a gasket for it also. The "manifold" might be difficult because that determines much to do with the compressor application.
It's not unusual for a new to be less the manifold. A salvage yard buy or a WTB in the parts section here might get it done. I believe you might need to limit your search to '92 & '93.
Old Jun 14, 2013 | 12:27 PM
SunCr's Avatar
SunCr
Manifold is correct.
LT Motors switched direction with the hoses coming over the front of the compressor - L98's are over the rear.
Do you have the Main Hose Assembly? That's critical because an R134 setup uses Sealing Washers and the inlet/outlet at the Manifold is flat. R12 (which is what came on your Vette) uses O-rings and the inlet/outlet is recessed. It's either one or the other as neither is interchangeable so I'd get the hoses first, then look for the Manifold.
Old Jun 14, 2013 | 10:36 PM
Atl_monte's Avatar
Atl_monte
yes I have the hoses
To Where to find missing A/C component
