Ignition Key Lubricant??
Old Jun 25, 2002 | 09:55 AM
LT4BUD's Avatar
LT4BUD
Default Ignition Key Lubricant??
The ignition switch on my 96 has become very difficult to turn off, almost like mechanical interference. The little button you push in doesn't seem to release the switch properly. Will a lubricant help?? What lubricant?? Anyone else have this problem??
Old Jun 25, 2002 | 11:32 AM
Tim06's Avatar
Tim06
Default Re: Ignition Key Lubricant?? (LT4BUD)
I had a problem getting my key out of the ignition. I used powdered graphite and it worked great. I don't know if it will help turning the car off but its worth a shot. Hope this helps.
Old Jun 25, 2002 | 11:45 AM
Corvette0096's Avatar
Corvette0096
I use silicone. That should get things moving.
Old Jun 25, 2002 | 07:52 PM
LT4BUD's Avatar
LT4BUD
Default Re: Ignition Key Lubricant?? (Tim89)
Sounds like the same problem, can't get the key out either
Old Jun 26, 2002 | 03:55 AM
dublinvette's Avatar
dublinvette
try white lithium grease.
To Ignition Key Lubricant??
