I thought I had all my ecm wiring straightened out and I may have but I've got a real head scratcher here. I can start the engine and the fan stays off like it should, but if I shut it off & re-start it the fan comes on as soon as the engine fires. I just had a similar problem and tequilaboy & coupeguy2001 both helped me out but now I have this. I believe my car has a normally closed a/c pressure switch but I have an '88 Firebird memcal in the ecm. Could the problem be the memcal or could I have a bad a/c switch? If it is the switch, there are two of them in the high pressure line, do I need the big one or the little one?
Little one. The big one is for the compressor clutch.
Try disconnecting it. That would simulate a N.O. switch. If that doesn't turn off the fan, short the connector to ground, which would simulate a N.C. switch.
....Try disconnecting it. ...If that doesn't turn off the fan,
No.
when switch is open = fan on (Logic high)
When switch is closed = no fan (Logic low)
From the helms manual : A.C high Pressure Switch opens at 233psi, Closes at 180psi.
If you want to test if the switch is causing fan to run (always open), disconnect the connector and jumper the two terminals to each other. The fan should stop, if it's the A/C fan request causing it to run.
To sort this out, there are 4 things that need to be determined by the OP:
Does car have an NO or NC A/C high pressure switch? (NO switch is assumed for 85 Corvette). I thought it was NC but I'm not sure.
Is bin configured for NO or NC switch? (NC setting assumed for 86-89 Corvette based bins). Memcal is stock, '88 Firebird tpi
Is pin D11 actually connected to the A/C high pressure switch or something else on the car? Yes, checked with cont. tester
Is pin C1 actually connected to the main fan control relay (pin B) or something else? It almost has to be, it is the only wire I can trigger the fan with.
Until these points are understood we are all working in the dark.
I just checked the wiring again to be sure, it is as I said. I started the engine with the fan connector on, fan came on as soon as I started engine.
I then disconnected the switch, first start, no fan, second start, fan on.
I then jumpered the terminals of the connector, fan on at start.
I then left it jumpered & grounded the jumper, fan on at start.
Then I grounded just one terminal, fan on second start.
Grounded other terminal fan on at start.
What's with the fan not coming on at first start but coming on at re-start? I think Willie may be on to something.
Would be helpful if you can record the datastream during an event. Can you scan the car at 8192 baud and save a log file with TunerPro, Datamaster or equivalent?
Are you getting an SES on the 2nd start, if so any stored codes?
The info here suggests that the A/C on/off status can also influence the driver's side fan (or main fan in Corvette speak) independently of the A/C high pressure switch.
I think you would be better off using a Corvette based bin that is correctly configured for your car's switch.
We need to know what's really in your bin file to make sense of this behavior.
If you have a programmer, can you read and copy your current bin file?
What is the broadcast code on the eprom of the 88 Firebird tpi memcal? Look under the blue cover for a label on the eprom.
Note: F-bodies typically have NO switches, so we may have a match.
If you can determine the broadcast code (bcc), I can check the bin if I can obtain a copy of the file somewhere.
AKFN
I just got datamaster to work the other day so yes I can scan it. No SES, no codes. I just tried something new, I have a piggyback with a custom tune on it that I put in. The fan is now functioning the way it should but I can't even drive the car with the piggyback in there, it idles rough and backfires out the exhaust. However I believe this tells me the problem is the memcal, am I on the right track? I bought the memcal off fleabay so it is hard to tell what someone has done to it, I'm guessing the memcal and the piggyback are working against each other. ???
I have no way of reading the bin file, but I can email it to you. PM me your email address & I'll send it out.
Edit: Never mind, I was so po'd about the tune being so rotten I threw out the email that had it.
Now that's not likely to happen, look at the mess I made of this project so far. Nope, I'm too old for this technology, I'll leave that to you younger & smarter guys.
when u start it, is the AC on or off? If my ac is on, the fan comes on right away. If not, it takes a while before the fan will run.
I have a corvette chip you can try, remember?
AC is off, never have had it on while working on this mess. I do remember your offer and if the one I am going to try Monday does not work I will take you up on the offer. I'll let you know. It's so weird, this all started when the fan would come on with the piggyback in place like yours did. With just the memcal the fan was staying off but I did not know at the time that it was wired wrong and would not even run with the ALDL grounded. Once I got the wiring right (?) the fan is now coming on with just the memcal but behaving as it should with the piggyback in place. I'm going to go over the ecm wiring again in the morning and then I am going to wrap all the harness back up & put it in the covering, I'm confident now my memcal is my problem.
I've got you & tequilaboy, along with others on this forum who are helping and I have another good friend on the thirdgen forum who is going out of his way to get me straightened out. With a force like that I can't lose.
