Backup lights wont work
Old Jun 25, 2002 | 10:11 AM
LD85's Avatar
LD85
Default Backup lights wont work
I assume its the tranny button, fuse or lights themselves, anything else possibly to look for?
Old Jun 25, 2002 | 11:44 AM
Guest
Guest
Posts: n/a
Default Re: Backup lights wont work (ld85)
All those plus the manual indicates the ignition switch, although I would think you would have other problems if that was the case.
The list is;
Gear Selector Switch misadjusted
Loose Connections
Blown Fuse
Defective Backup Switch
Defective Ignition Switch
Disconnect the backup switch and insert a paper clip, turn-on ignition and see if they light or check the switch terminals with power off and connecting a ohmmeter check for continuity.
HTH
Old Jun 27, 2002 | 02:25 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Backup lights wont work (Mark84_L383)
That's true. Also, the Turn Signals are on the same fuse, so if they work, the Ignition Switch and Fuse are good.
Yes. My money is on the switch. That's what wore out on mine.
Old Jun 27, 2002 | 07:59 AM
LD85's Avatar
LD85
Default Re: Backup lights wont work (Ray Quayle)
Thanks Ray, long time no hear! Your right it was the switch!
[Modified by ld85, 7:00 AM 6/27/2002]
Old Jun 30, 2002 | 06:12 PM
rrankins's Avatar
rrankins
I think I have the same problem and have a replacement switch - question is - where the heck is it? Do you get at it from underneath, or can you replace from top by removing the console?
Thanks,
Ray Rankins
To Backup lights wont work
