ECM Connector problem, I think
Old Jun 15, 2013 | 11:36 AM
wdsj's Avatar
wdsj
Default ECM Connector problem, I think
91 L98
I have realized several of my sensor issues share the same ECM connector. On inspection, the tab the holds the connector together on the green plug is broken off. The tab that holds the wires in place, not the ones that hold the connector to the ECM.
with the car running, I can press on the connector and the engine revs up, release and it goes back to normal. If I hold pressure on it, several inputs go wackey and the engine dies (I am monitoring with tuner pro).
Not sure what causes the engine to rev, but I noticed the idle setting goes from 775 to ~3500 rpm and the TPS goes to ~25%.
I think I need a new connector. Anyone know where to get one or how to I can repair?
Old Jun 15, 2013 | 09:54 PM
bob guzzy's Avatar
bob guzzy
That ECM is shared by many models I just saw a link to it today somewhere in the parts section.
It's shared by quite a few vehicles that can be found in many salvage yards, I can't see why you couldn't get a new plug and a length of wire from it, then solder in the wires.
Old Jun 15, 2013 | 10:06 PM
JackDidley's Avatar
JackDidley
You may be flexing the circuit board in the ecm when you do this.
Old Jun 16, 2013 | 10:33 AM
wdsj's Avatar
wdsj
agree with both replies. The ECM is new/refurbished though that does not mean much.
I can get one from a yard, just though someone out there would sell them as they are quite common.
To ECM Connector problem, I think
