code 34
Old Jun 15, 2013 | 12:45 PM
Grenkepr's Avatar
Grenkepr
Default code 34
Had a code 15 so replaced the temp. sensor. Cured that code, but now I have a code 34 which I didn't have before. What is code 34 ?.1988
Old Jun 15, 2013 | 12:52 PM
Ghast's Avatar
Ghast
Code 34 is the MAF sensor.
Old Jun 15, 2013 | 02:23 PM
Grenkepr's Avatar
Grenkepr
Thanks........
Old Jun 16, 2013 | 01:01 AM
vetteoz's Avatar
vetteoz
How to fix
http://www.chevythunder.com/maf_code_34.htm
Old Jun 16, 2013 | 04:10 AM
Cliff Harris's Avatar
Cliff Harris
To be more precise, code 34 is low MAF signal.
Could be the MAF to ECM wiring is shorted to ground.
MAF power relay and/or its associated wiring could be bad.
Old Jun 16, 2013 | 04:22 AM
vetteoz's Avatar
vetteoz
That would be why you work through the fault diagnostic chart I linked above
Old Jun 17, 2013 | 03:44 AM
Cliff Harris
The chart doesn't mention the MAF power relay. Or how to troubleshoot it.
It also says "No code 12" on the lower left side, which probably ought to be "No code 34".
On the 1985 MAF diagram the block labeled "MAF BURN OFF RELAY" could be more accuratly labelled "MAF BURNOFF MODULE" -- it has both power and burnoff functions -- and some electronic circuitry inside.
To code 34
