ZF Clutch Help
Old Jun 25, 2002 | 01:43 PM
John G 92's Avatar
John G 92
Default ZF Clutch Help
I was wondering how did you guys remove the Throw out fork. I can't get it out so the bell housing won't come off. I was wondering did you guys have to remove the Alen that holds the throw out ball to the bell housing?
car is a 92 LT1. :confused:
Old Jun 25, 2002 | 01:48 PM
FRANX C4's Avatar
FRANX C4
Default Re: ZF Clutch Help (John G 92)
Yes I removed the stud and then the fork was loose inside the bell housing. The small allen you see on the outside is a cover, once removed you will see a large alen to remove the actual stud. I think it was 18 mm.
Old Jun 25, 2002 | 01:53 PM
John G 92's Avatar
John G 92
Default Re: ZF Clutch Help (FRANX C4)
Yes I saw that I didn't have the size alen you sure it's an 18 mm I was thinking somewhere like 12-14mm If there is anyway you can tell me for sure it would help I have to go find one today. my car is at a buddys house 20 minutes from me. where I'm doing the work.
I just found the info it's a 12mm alen thanks to the ZF51 performance site :cheers:
[Modified by John G 92, 12:57 PM 6/25/2002]
Old Jun 25, 2002 | 05:54 PM
FRANX C4's Avatar
FRANX C4
Yeah 12 seems more like it. I don't know what I was thinking.
Old Jun 25, 2002 | 06:30 PM
devilfish's Avatar
devilfish
then you unscrew it clockwise...
To ZF Clutch Help
