I got my driver side half shaft put back together today. What a trip!
I've found torque soecs for everythung except the camber strut bolt, which I think should be 30#, also the speed sensor bolt in the knuckle and the two caliper mounting bolts.
I have to pull my caliper mounting bolts, clean the threads and put some never sieze on them.
Any help appreciated
Not sure about the torque specs. Don't have my fsm in front of me. Best investment you can make. You don't want to put antiseize on caliper mounting bolts. If anything, you want to use locktite. You don't want those bolts backing off.
Knuckle to strut bolt 107# Must be torqued at ride height.
I didn't look up sensor bolt, but it will be in inches as it doesn't require much torque at all.
