Stutter under Part Load
I recently bought a 1988 Corvette Coupé with the 4+3 manual transmission. It's in lovely condition and only has 33,000 miles on it, but it has one serious issue:
When cruising at constant speeds, especially around 1000-1500 rpm, a strange stutter occurs. As soon as I start accelerating gently, it stops instantly. After cold start everything is perfect. But
the warmer the engine becomes, the heavier the jolts are.
Until now practically everything related to the engine has been replaced: New spark plugs, wires and capacitor, new temperature sensor, new injector nozzles, new ECM ... nothing worked.
American cars are very rare in Europe and therefore it's difficult to find a practiced mechanic for a Corvette. So you really are my last hope!
Thanks in advance for any ideas!!
Any fluctuation of the volt meter during this stuttering?
Does your brake power booster make a hiss noise when you apply brakes?
Have you cleaned the EGR valve and its associated plumbing?
Remove the power tube (flex air intake hose) from the throttle body and work the throttle from closed to open. Does it move smoothly? are the round holes that hold the axel of the throttle plate still round or are they oval?
Have you cleaned the idle air controller?
In general it sounds like to me you've got some un metered air entering the system.
Is it enough just to replace the gaskets on the throttle body or do you think that a major leak is necessary for this problem? Is there a way for me to verify your assumption?
Also check the voltage goes to at least 4.5 volts with full throttle .
After changing the ECM, things are much better, but I'm still not content with it, as there still are little jolts when cruising. Probably I wouldn't feel it if it was an automatic, but I want to stick with the original manual box. Apart from that, I just can't believe that a car that was once called on of the best cars in the world behaves like that.
