Headlight motor question.
Old Jun 25, 2002 | 08:08 PM
Cap'n Rich's Avatar
Cap'n Rich
Default Headlight motor question.
My left headlight motor continues to run for 3-4 seconds after the pod has hit the stops - both ways, opening and closing. The right one quits immediately, as it should.
What causes the motor to shut off? Is there an internal limit switch or does it detect the increase in torque? I haven't found any text on this in the service manual.
TIA,
Rich
Old Jun 25, 2002 | 08:23 PM
AS84's Avatar
AS84
Default Re: Headlight motor question. (Cap'n Rich)
sounds like the delrin bushings located underneath of the drive gear inside of the motor. 5 dollar part but what a P.I.T.A! Do a seach on this topic and you will find many posts on this subject.
Old Jun 25, 2002 | 08:33 PM
Cap'n Rich's Avatar
Cap'n Rich
Default Re: Headlight motor question. (AS84)
I'll do that, Aaron. I have seen headlight motors discussed before, but IIRC most of those problems were inoperative motors or motors which shut down prematurely instead of running too long.
Rebuilding stuff like this is my kind of job. I love to take electrical junk apart and make it better than before. I'll even rewind burned-out transformers for a furnace thermostat just to save the ten bucks for a new one! Relay scorched? No problem. Just make new points for it. :D
Rich
To Headlight motor question.
