Coolant leak 1986
Old Jun 22, 2013 | 09:56 AM
rangepony69's Avatar
rangepony69
Default Coolant leak 1986
Not sure where to go now.......I have a coolant leak under the engine on the right side. It only leaks when the engine has just been turned off, still under pressure and warm. No leak when cold or running....leak is small, about the size of a good pancake once the engine has been stopped. The heater box/suitcase is dry, leak appears to come from the union of the transmission and engine at the bottom of the right side just behind the right front tire. Strange huh?
Any help/thoughts would be appreciated.
Rangepony
Old Jun 22, 2013 | 10:57 AM
desertmike1's Avatar
desertmike1
You need to get your self a bright flashlite and trace it, it's either leaking down from above or from the back of the Block (Freeze plug)
Old Jun 22, 2013 | 12:30 PM
rangepony69
10-4...........I did that this morning and my first reaction was freeze plug..............wonderful news................
Thanks for your thoughts.
Old Jun 22, 2013 | 03:45 PM
lkl2005's Avatar
lkl2005
My 86 had a leak at the right rear corner of the intake. Good artificial light is good. Get it out there in the sun light and use your nose also.
Old Jun 22, 2013 | 04:24 PM
ch@0s's Avatar
ch@0s
You can rent a pressure tester and look for the leak when its cold. The TPI is famous for leaking intake. My 86 and 91 were both leaking in the right rear . GL with it
Old Jun 22, 2013 | 05:15 PM
rangepony69
Thanks for all your responses. I'm going to clean the area in the right rear and see if I can see anything. I also need to clean/paint the valve covers so I'm thinking I may take it all apart and do it all at one time. Good thing I'm retired..............
Rangepony
Old Jun 22, 2013 | 11:13 PM
Cliff Harris's Avatar
Cliff Harris
Check the steam line -- the small pipe and rubber hose that goes from the heater hose to the rear of the intake manifold on the passenger side. Mine had a pinhole leak in the bottom that was otherwise invisible. I only found it by accident when i happened to see water leaking in that area. It had been leaking for quite a while, based on the rust on the frame.
One of the heater hoses could be leaking.
The water valve on the heater manifold might be leaking.
Old Jun 23, 2013 | 07:38 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
I don't see how your water pump could be leaking because you say the system is always full except for the reservoir.
To Coolant leak 1986
