I'm sure the answer is here but I can't find. It's blowing hot air. Showed code 09 low freon. Hooked up gauges. Static presure is 120 on high and low side and same with engine running. Compressor not engaging. I direct wired compressor to battery and it engages. When engaged pressure drops to 40 on low side and 240 high. Disconnect compressor from battery and it all goes back to 120. Freon isn't low. Any help is appreciated
If it continues after you've cleared the Code, there might be a faulty Pressure Sensor or Low Pressure Switch. Ohm out the Low Pressure Contacts. Should be closed with 120 psi static. You'll need a Scanner for the Pressure Sensor, but it should show about 1.2 volts and that voltage needs to rise when the compressor engages. Otherwise, if there's no Codes and it doesn't engage, try a new Relay.
No AC expert for sure, but the static pressure of 120 seems really high unless the ambient temperature was really hot, like 90 to 100 degrees. Just going from memory, it seems like it should be about 70 pounds on a 70 degree day. Something like 84 on an 80 degree day. When you got the compressor going, did it start to cool air?
Engine Heat; R134 is 98 degrees at 120 psi; R12 - 102. Neither would be unusal if it had been running.
I appreciate all the advice. Just to update. I pulled the ctsy and radio fuses as well as disconnected negative terminal in order to clear the hvac programmer. Started the engine, put on max ac. With multimeter I checked voltage at hi pressure switch. 13.2 volts. Followed wire to low pressure switch, also 13 volts. This leads to dark blue wire at compressor. It also has 13 volts. Compressor doesn't engage. If I run wire from battery directly to compressor, it engages and I get 45 at the vents. I also did ohm test. Hi pressure was 0.00. Connector at compressor was 0.00. Low pressure switch was driving the meter crazy. All kinds of numbers flashed and then stopped at 1.
I'm going to try a new low pressure switch. For $10 it's worth a try. If the switch is bad I can't understand how I have voltage at the compressor.
You need to check the low pressure switch with the connector OFF. If you put voltage (if connector is on) into a meter measuring resistance, it will drive it nuts or blow it up. The switch should read either closed (zero ohms), or open (infinity). That the only 2 measurements you will get. You don’t have to run the engine to take initial resistance measurement. Static pressure is plenty to close the switch.
