Fan Switch thru Firewall????
Old Jun 25, 2002 | 10:58 PM
YorkL8apex's Avatar
YorkL8apex
Default Fan Switch thru Firewall????
I'm installing a manual fan switch on a 91, L98 Auto Coupe. Where is the easiest place to penetrate the firewall with the wires going to the fan relays? Mid America says to go through with the Cruise Vac Line.
Seems I saw some posts saying there was an easier access?
Old Jun 25, 2002 | 11:05 PM
MrNuke's Avatar
MrNuke
Default Re: Fan Switch thru Firewall???? (York67vette)
Thats what I used... didn't find any easier place to snake it through..
Old Jun 25, 2002 | 11:40 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: Fan Switch thru Firewall???? (MrNuke)
I went in on the driver's side, sort of near the cruise and mounted the switch to the right of the stereo. Mr. Nuke, those 17" sawblades and 315's are on the car and look sick! :D:D:D:D
Old Jun 25, 2002 | 11:44 PM
Ricks1989Roadster's Avatar
Ricks1989Roadster
There should some rubber "bungs" on the firewall that are unused. I took one out and made the correct size hole and slid the wiring through. I believe these unused "bungs" were used for linkages on a manual Vette. Hope it helped.
Old Jun 26, 2002 | 09:59 AM
YorkL8apex's Avatar
YorkL8apex
Default Re: Fan Switch thru Firewall???? (Ricks1989Roadster)
Thanks Guys! :blueangel: I'll look harder tonight, just made a quick recon last night and did not see an easy way in.
Old Jun 26, 2002 | 10:29 AM
FlyboyZR1's Avatar
FlyboyZR1
I don't see any reason to go through the firewall. I routed my wire behind the weatherstripping on the driver window, and then right down by the battery. You can't even see the wire. Much easier than going through the firewall. IMO
Old Jun 26, 2002 | 05:58 PM
YorkL8apex's Avatar
YorkL8apex
Default Re: Fan Switch thru Firewall???? (FlyboyZR1)
Now that may be right in my ability power curve Flyboy :smash:
Thanks!
To Fan Switch thru Firewall????
