Throttle Body Will Not Close Completely
Old Jun 24, 2013 | 01:35 PM
rube1975's Avatar
rube1975
Default Throttle Body Will Not Close Completely
Hey guys I really need you experience/ideas on this one.
1989 L98 6 speed, Throttle Body Will Not Close Completely. It is staying open about 1/8". If I close it by hand the engine runs perfect.
So I replaced all 8 fuel injectors (22lbs) this weekend. Added a Adjustable Fuel Pressure Regulator (42.5psi) & new EGR valve. I also did a coolant bypass on the throttle body and Cleaned the TB with a can of carb cleaner.
This problem DID existed before I replaced the fuel injectors. (I did think it was a by-product of the bad fuel injector)
I did check the TPS and it was a perfect .58 @ idle (& 4.3 WOT). I did not attempt to adjust the IAC.
While I was driving I guessed it would be some vacuum hose but know i feel a bit lost. It did fell like it was down on power but I can say for certain.
All ideas welcome.
Fingers crossed I dont need a new TB
Old Jun 24, 2013 | 04:46 PM
jmgtp's Avatar
jmgtp
Possible the bearings are worn and the blades are contacting the bore and hanging up. I'd remove the linkage first and see if it operates smoothly to eliminate them as the source of binding.
Old Jun 24, 2013 | 05:10 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Did you try adjusting the idle-stop screw? If TPS is set "correctly", maybe someone opened it, and reset the TPS. Maybe they did so -- in response to bad injectors?
Seems like you'd be running too fast on the idle though....after swapping in new injectors.
No way it SHOULDn't be running (idling) too fast with the TB open too much.
Maybe the timing is off too?
Old Jun 24, 2013 | 08:49 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Does it close and idle with the cable removed from TB linkage ?
Old Jun 24, 2013 | 10:05 PM
rube1975's Avatar
rube1975
Hey guys thanks for the replies. I will check the linkage cables to be sure the move smoothly.
I didn't touch the idle screw since the factory plug was still installed and did not appear to ever been knocked out. Also when I had the bad fuel injector in the engine would idle as low as 450 while hot. Idk of that is worth anything though.
When I cleaned the tb it would snap back to the screw. It was in the 90s in Boston today. How outrageous would it be to think the weather is a factor? I'm guessing that isn't the sole issue but worth asking. Updates coming. Thanks again
Old Jun 25, 2013 | 01:24 PM
rube1975's Avatar
rube1975
Alright still scratching my head b/c of this one. First I checked the cables. They are taunt but not tight. Seemed like it is as it should be. I pulled the TB cables off and started the car. The TB would still not close completely on it own staying open just a bit to cause a high idle like yesterday.
I shut the car off and stroked the TB and it did shut as it should. So I was thinking vacuum leak. I sprayed carb cleaner on both ends of the runners, the ERG, the nozzle end of each injector, and the plenum side of the TB & the rev's stayed flat (judging with my ear). I have never tested Vacuum that way (or any way); so Im guessing that if there was a leak the rev's would pick up a noticeable amount.
I'm just realizing I should start the car and get it to stick open a bit and then shut the car off to see if it returns or stays put. I will do after work.
I guess that only leaves the timing to be checked. Can this be done with the ALDL cable I've read about? Or should I buy a timing light?
Both?
I have 22lbs/hr injectors @42.5 should the fuel pressure be higher than that?
Old Jun 26, 2013 | 11:52 AM
rube1975's Avatar
rube1975
bump
Old Jun 26, 2013 | 12:32 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
If the butterflys are not closing completely when the cable is disconnected,
there is a mechanical problem with the TB.
Remove, disassemble, clean, inspect, reassemble.
Quit chasing around and get your initial problem fixed first.
Old Jun 26, 2013 | 12:33 PM
DanielRicany's Avatar
DanielRicany
Hi, try this first before you do anything else!
This passed week, I was experiencing the same problem. I would drive and come to a stop light and idle at 1100 - 1400 rpms at times. The only way to get it to stop would be to tap the gas. So I figured it wouldn't be the IAC valve since tapping the gas stopped the problem temporarily, so I thought, okay, stuck throttle plate.
I pulled over when it happened one day and I did notice my throttle plate was open a little bit, and when I closed it the problem went away. I brought it hope, took off the snorkel, and sprayed the linkage and all pivot points of the cables with WD40. I opened the throttle body and sprayed the throttle plate bores (4 internal). Then I also sprayed the bore on the outside right next to the TPS. Work the throttle plate back and forth while you keep do this 5 times. Get in your car and go for a ride. Mine got stuck one more time, and then the WD40 worked its way in and it doesn't do this anymore.
If this solution doesn't work, because it doesn't always, then you will need a new throttle body. If it comes down to that, I recommend go with a bigger throttle body, (if you want to put some more power into it.), but if you aren't going to put a bigger intake into the car, or port and polish, then don't go too big.
Best of luck to you!
Old Jul 1, 2013 | 06:55 AM
rube1975's Avatar
rube1975
Hey Dan Thanks for the tip it worked like a charm!
To Throttle Body Will Not Close Completely
