Hi all. Can anyone direct me to a post on replacing the Pickup Assembly and mounting the distributor for a 1991? I believe I have it all put togeter correctly but want to make sure and confirm the mounting. Thanks.
No, it's the pick-up assembly that sits inside the distributor around the distributor shaft next to the ignition module.
Oh: http://www.autozone.com/autozone/rep...00c1528008faaa
here is a how to on the Pick up coil. If I were you I would turn the motor over util the rotor point at the #1 spark plug wire before I remove the distributor and just make sure to put it back in the same place when done.
