AC and fan questions.....HELP
Old Jun 27, 2013 | 11:49 AM
Shimy86's Avatar
Shimy86
Default AC and fan questions.....HELP
First, I only have high or off with the fan. Is there a relay or fuse for the lower speeds? This is all the time, not just with ac on
Second, can a guy get a can of R-12 anywhere anymore??
Any help with either would be greatly appreciated!!
Old Jun 27, 2013 | 01:36 PM
ch@0s's Avatar
ch@0s
IDK about the R-12 but it sounds like the blower control module is out.
Old Jun 27, 2013 | 08:29 PM
GQ-ROD's Avatar
GQ-ROD
You can get cans of nos r12 on craiglist, and on ebay, however you will on ebay have to sign a waiver that states you will be selling it to a certified tech. Easy enough.
Or you could get your certification online for about 25.00 and be able to walk into any supplier and get in 30 pound size bottles of R12. Pricey but worth it since if you are going to do your own a/c work keep it simple and stay with r12.
Try and get dupont r12.
As for the speeds chances are depending on year/model it's the blower motor resistor.
Old Jun 28, 2013 | 02:42 AM
Hot Rod Roy's Avatar
Hot Rod Roy
I'm confused. What year 'vette? Might it be an '86? The tat says otherwise!
Yes, problem could be the resistor, but not likely since all 3 lower speeds don't work. Most likely the speed control relay, that's located below the fan motor (passenger side f'wall). Look for overheated wires on the connector. There's an aluminum rivet in the relay that carries a lot of current that gets hot.
Old Jun 28, 2013 | 03:05 AM
vetteoz's Avatar
vetteoz
C60 or C68 ?
Old Jun 28, 2013 | 10:10 AM
pcolt94's Avatar
pcolt94
Originally Posted by vetteoz
C60 or C68 ?
Sounds to me it's probably a C60.
If it is, I would probably check the (assuming that it has one) resistor network in the evaporator box. Also pay close attention and look for any broken wires or corroded/burnt terminal connections.
Sounds like a ground return opened up and there is no voltage drop on the divider network and the blower mower is getting full 12 volts.
Old Jun 28, 2013 | 10:18 AM
DanielRicany's Avatar
DanielRicany
Hi, I had looked up a wiring diagram for your blower motor. This doesn't use a resistor block, but rather a Blower Control Module, which is what you will be replacing.
Old Jun 28, 2013 | 10:20 AM
Shimy86's Avatar
Shimy86
last fall before i put it away I also blew a fuse for the interior lights? relpaced the fuse and they work again. Coincidence or related?
Old Jun 28, 2013 | 10:34 AM
DanielRicany
Well there has to be a reason as to why is blew.
Old Jun 28, 2013 | 12:06 PM
Shimy86's Avatar
Shimy86
On an 86 is it located below the blower motor?
Thanks!!
Old Jun 28, 2013 | 01:16 PM
DanielRicany
Hi, I'm not sure about 86, I have an 85 and mine is on the top of the heater box. It should be within the pathway of airflow before the air gets to the heater core or evaporator. Somewhere in the heater box.
Old Jun 28, 2013 | 07:53 PM
vetteoz's Avatar
vetteoz
Only if it is C68 which is why I asked the question above ( which the OP still hasn't ANSWERED)
C60 has the relay and resistors as shown
Old Jun 28, 2013 | 07:54 PM
vetteoz's Avatar
vetteoz
Old Jun 30, 2013 | 02:15 AM
Hot Rod Roy
The picture posted by Vetteoz is the Blower Resistors (see his schematic). The High Speed Blower Relay (see schematic) is located below the fan motor (if it's the C60 a/c system).
Old Jun 30, 2013 | 02:36 AM
vetteoz's Avatar
vetteoz
Or the BCM ; depending on what you have
Old Jul 1, 2013 | 02:50 PM
Shimy86's Avatar
Shimy86
Dont know if its a C60 or C68, dont know what that refers to. I cant look at car right now as it is in the bodyshop getting a bad spot fixed. Hope its the control module cause thats only $19
Old Jul 1, 2013 | 10:14 PM
Cliff Harris's Avatar
Cliff Harris
C68 is the automatic HVAC system.
C60 is the manual HVAC system.
They have vastly different components so it's important to know which one it is before we can give you accurate advice.
To AC and fan questions.....HELP
Old Jul 2, 2013 | 10:52 AM
Shimy86's Avatar
Shimy86
its the C60 manual system......Thanks for any help!!!
Old Jul 3, 2013 | 10:22 PM
Shimy86's Avatar
Shimy86
The bcm looks fine? If wire loops are good is it okay? When I use a jumper wire on the plug that goes to the switch I get high fan thru each terminal. When pluged in nothing on any setting except high.........help please
Old Jul 4, 2013 | 12:32 AM
vetteoz's Avatar
vetteoz
The bcm looks fine?
C60
You don't have a BCM ; you have resistors
Which switch , the one in the dash
Got a DVM?
you need to check the resistor pack for continuity and the dash speed selector switch to see if it is working.
It may not be switching across the Lo speed circuits
