Won't restart after engine warms up. Please help!
Old Jul 4, 2013 | 02:26 PM
indianavette's Avatar
indianavette
Originally Posted by MrWillys
I just went out and put a fuel pressure gauge on mine. Turned the key forward and jumped up to 48 psi and a full 2 minutes later was still above 40.
With this being said, did you have the problem prior to the swap to the Accels? I've got a friend that just had brandnew Accel 48's and one was bad. You could disconnect the cold start after starting, and see if it makes a difference upon hot start. I'm leaning towards one of the new Accels going short to ground once it warms and flooding.
Your symptoms are identical to mine. In my case, the culprit was that short rubber hose connecting the fuel pump to the modulator. It had a tiny tear thru which fuel gushed when the pump was activated. Don't know why it didn't affect cold start as well as hot. But a new hose solved my problem. Here's hoping yours turns out to be an easy fix.
Old Jul 5, 2013 | 12:21 AM
Cliff Harris's Avatar
Cliff Harris
The cold start injector is controlled by the cold start thermo switch on the front of the intake manifold. It is powered by the starter solenoid and only gets power while the engine is cranking. It has a thermal element inside that times out after 8 seconds. It also measures the coolant temperature and will not turn on if the coolant is over 95°.
Old Jul 5, 2013 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by AGENT 86
What is missing when it won't start hot
Spark ?
Fuel ?
Checking spark is easy, for fuel, a noid light is handy.
Since you have a fuel gauge, you could pull the fuel pump fuse after it is primed and then look for a pressure loss during cranking.
Have you checked to see if the fuel is actually being delivered ?
The ignition control module is responsible for sending the reference pulse to ECM. Without the reference pulse, the ECM will not fire injectors.
The module may fail when hot, so you need to check with a noid light or the test I mentioned above, to see if fuel is being delivered.
Old Jul 5, 2013 | 04:12 PM
Rawkmann's Avatar
Rawkmann
Coolant temp sensor? Had this exact problem in my 94 and that turned out to be the fix.
Old Jul 5, 2013 | 06:07 PM
MrWillys's Avatar
MrWillys
My mistake, you're correct. This actually helps me in my understanding. Thank you.
