I just finished rebuilding the front suspension and steering rack on my 85. I did the rebuild because the car wandered and pulled on uneven surfaces. Over the last 5 years my tires had worn perfectly. I installed new poly bushings, ball joints, tie rods and had the steering rack rebuilt by Turn One. I did not replace the upper control arm bushings. They looked to be OK and I didn't want to deal with pressing new bushings in.
I had a local shop do the alignment. The Tech checked caster and camber and left them as is. He adjusted the toe.
Actual LF Camber -0.1 Factory +0.3 to +1.3
Actual RF Camber -0.2
Actual LF Caster +4.9 Factory +2.3 to +3.8
Actual RF Caster +4.7
Actual LF Toe -0.01 Factory -0.10 to +0.10
Actual RF Toe +0.01
I'm curious what others are setting caster and camber to. Should I go with positive camber like the factory specs? And do I need to reduce caster? By the way, this is a street car that I may do some autocross with.
just for info my settings on my 85 ;
FL Camber -1.2
FR Camber -1.1
FL Caster +3.7
FR Caster +5.1
F Toe +0.2 mm
RL Camber -1.1
RR Camber -0.9
Rear Toe +0.8
this combo works well on mine, and hasnt chewed out the tyres yet (not a daily driver !)
Reason: finish
Sorry, Daniel, but I can't agree with this analysis. Changing the caster in a Corvette won't affect the angle of the shock. Negative caster will cause the car to wander, and the steering wheel won't return to center on its own. The +5 degrees caster recommended by several people is an excellent suggestion.
If you want to test this negative caster idea, try backing up fast, turn the steering wheel a bit, then take your hands off the wheel! (Be ready to step on the brakes!!)
My basic parameter for any performance alignment on any car is a tad of toe out for turn in (1/16th), Negative Camber to taste (RRing -2-3 deg if you can get it) and positive caster in the 5-6 range if you can get it. Many cars are limited on caster once neg camber is dialed in. On an autox I like rear toe about a 16th or 8th out. On a track I like rear toe neutral or a 16th in.
For a street car zero toe, neutral camber, and 5 positive caster will generally work on any rear drive car. On a 4 wheel alignment neutral toe and camber on the rear also.
Negative camber will wear out the inside of the front tires when you are street driving so be careful. I generally limit street driven cars to 0.8 negative camber or so and that is only if you actively autox. Many will also add their desired autox toe out by moving the tie rod a couple of flats when they arrive at the event.
IMHO - there is no right or wrong alignment spec. It's all a big compromise. As other posts have pointed out, what you plan to do with the car drives the train. More neg camber will improve your autocross times, but at the expense of tire wear and the car wanting to follow the "ruts" that seem to be everpresent in our highway system. In my experience - it's hard to get a stock C4 past about 1.5 degrees neg camber - but if one were to "thin down" the factory control arm "spacers" you can find a bit more than that. Normal street driven cars are typically set up with a bit of toe in - this helps prevent toe out when the steering system develops a bit of slop. Toe out is commonly used on race cars, and makes the car want to turn in - including when you're driving down a straightaway (read that as toe out induces some instability - great for Road Atlanta, not great of I-95). You really don't want any rear toe out - some experienced road racers use it, but it can make for attention getting moments......
Remember - on a C4 - camber adjustment changes toe, meaning toe is ALWAYS adjusted last!!!
My "recommendation" for a nice street ride that occasionally gets to an autocross would be to start with about half a degree neg camber, and about 1/16 - 1/32 of total toe in. See how it feels and how the car drives. You can easily add some more neg camber - but tire weat will increase.
