Steering
Old Jul 2, 2013 | 11:50 AM
19774x4's Avatar
19774x4
Default Steering
I have a 91 coupe with 125000 on it, what is the best way to tighten the steering. Upper and lower ball joints????. Greasing semes to help but very little. A small bump will make the steering rattle and loose
Old Jul 2, 2013 | 12:09 PM
c4cruiser's Avatar
c4cruiser
Raise the front of the car so that the wheels are off the ground. Grab the tire at the 12 and 6 o'clock position and try to move the tire in and out. Is there any movement? Could be ball joints or a worn hub. Then grab the tire at the 3 and 9 o'clock position and try moving left and right. Slop here could indicate bad tie rod ends or worn out steering rack.
With that mileage and assuming the components are original, I would replace the 4 ball joints, the outer tie rod ends and get a replacement steering rack. New shocks on all 4 corners too.
Old Jul 2, 2013 | 12:14 PM
19774x4's Avatar
19774x4
Originally Posted by c4cruiser
raise the front of the car so that the wheels are off the ground. Grab the tire at the 12 and 6 o'clock position and try to move the tire in and out. Is there any movement? Could be ball joints or a worn hub. Then grab the tire at the 3 and 9 o'clock position and try moving left and right. Slop here could indicate bad tie rod ends or worn out steering rack.
With that mileage and assuming the components are original, i would replace the 4 ball joints, the outer tie rod ends and get a replacement steering rack. New shocks on all 4 corners too.
thanks that a good starting point
Old Jul 2, 2013 | 12:21 PM
cumbercr's Avatar
cumbercr
You might want to check the steering coupler for play. That's an easy and cheap fix.
Old Jul 2, 2013 | 04:53 PM
19774x4's Avatar
19774x4
Originally Posted by cumbercr
you might want to check the steering coupler for play. That's an easy and cheap fix.
thanks i will ck coupler
To Steering
