Bad Starter?
Old Jul 4, 2013 | 11:46 AM
cumbercr's Avatar
cumbercr
Default Bad Starter?
The starter cranks normally when the engine is cold. When hot it tends to crank very slow. I think the starter is the original. I may have fried it with heat from the headers I've been running the last 4 years.
Old Jul 4, 2013 | 12:14 PM
93 lt1 vette's Avatar
93 lt1 vette
Check the terminals on the battery for high ohm's and especially the chassis to the negative side of the battery. Corrosion and tightness. Hope the starter is good..
Old Jul 4, 2013 | 01:07 PM
Just BOB's Avatar
Just BOB
Year & Model
1985 Corvette
Color
Black
Mods
396 Stroker, Eagle forged crankshaft, Crower Sportsman Stroker rods, SRP forged pistons, AFR 195 Street Heads, Crower 221/230 cam, Super Ram Intake, TPiS 58mm throttle body, Bosch III 42# Injectors, Competion Cams Ultra Gold rockers. Pro-Built 700R4, Vigilante 2800 Stall Converter.
If you want help, you shouldn't make folks start with forensics to figure out background on the car in question! (it's a pet peeve of mine, so bear with me - at least you filled out your profile! )
That's a pretty potent mill you are trying to spin over!
As suggested, I'd check the battery and cables. Check battery voltage while cranking, and voltage drop across the cables as well. If you have a known good battery, swap it out and see if it cures the problem. Other than brushes wearing out, those old GM starters are pretty bullet proof.
Old Jul 4, 2013 | 01:37 PM
ch@0s's Avatar
ch@0s
My vote is the starter
Old Jul 4, 2013 | 01:59 PM
cumbercr's Avatar
cumbercr
Battery connections and grounds are all clean and tight. The negative battery terminal has 0.0 ohms resistance to the frame. Haven't checked cranking volts.
Old Jul 4, 2013 | 02:28 PM
ch@0s's Avatar
ch@0s
When you replace the starter put a heat shield on it. Come to think of it it could be just the solenoid.
Old Jul 4, 2013 | 02:33 PM
cumbercr's Avatar
cumbercr
I'm thinking the same thing. Any thoughts on a high torque mini starter?
Old Jul 4, 2013 | 02:34 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I am in agreement with chaos. It sounds as if the starter has an internal short which is worse with heat but by all means, check the solenoid first.
Old Jul 4, 2013 | 02:36 PM
Midnight 85
A mini is a good idea especially with headers but get a good one. I've had a couple go bad long before they should have just because I tried to save a buck.
Old Jul 4, 2013 | 04:47 PM
ch@0s's Avatar
ch@0s
I put an LT1 starter on mine when it was still a SBC.
To Bad Starter?
