Harbor Freight aluminum jack
Has anyone else used their jacks? I have had a 3 ton heavy steel jack for years and it works fine.
But this alum. jack worked once when putting my drag radials on. 2 weeks latter, was going to switch back to my street tires, and it wont pick the car up. Im wondering if they are junk and I should just get a refund or maybe I just got a bad one.
Looking for opinions and suggestions. Thanks in advance.
Edit to say, when I got it, I paid $59.95
I also have a PILE of other misc HF tools. Power tools, assorted hand tools.
About 1 of 4 times I will have to return a power-tool or some kind of mechanical item for exchange. They swap it no problem. If you pay the extra $5 or $10 at check out and get the extra warranty...its added piece of mind. I do not mind going back annually for a new grinder or drill....I have one now that has a 'date' for exchange....
The quality is marginal but most of the time the product DOES work right. Like I say, when something does NOT, it goes back for a refund or exchange and I've never had a problem and I've bought from HF at the Camarillo warehouse and a doz other stores since. Even the RC airplane worked fairly well...the pilot kinda sucked but the plane itself was great.
For tools that you need just to do a job they cannot be beat. if you want to collect and build an asset that's got actual value then buy snap-on. I have a buddy that's got well over $100,000 invested (insured for that much) in his cabinets, hand tools and counters that fill a 12 x 20' room...Mahogany work benches? really????
he has a warranty that's just as good or better, but I have more cash in my pocket than he does...its a matter of personal preference. ....and I don't freak out when something turns up missing. he DOES !
I don't trust them as much as I do my heavy jacks but when you have to lift the car that little bit to get a bigger jack to where you can jack up the car they are perfect for the job.
Just don't expect to lift the whole rear or front end using one, maybe one corner at a time but not the whole front or rear.
If everything looks clean and dry, it might be worth returning it for another one. Most of these small aluminum jacks are made by the same company but some of the HF versions are factory "seconds".
Your much better to look for a Original Black Hawk or Watco floor jack. They can be bought for reasonable money. Rebuild kits are available for short bucks. They will not fail like Chinese Stuff.
My quick test for a floor jack.....If I can pick it up and set it on the work bench without hurting myself...pass it by. My 3 ton Watco weighs just short of 160 pounds and will lift all day, every day.
Dont get hurt with junk.
8Valve
FWIW I really just purchased it to take on track days etc. I have a heavy long 3 ton steel jack that I have had for years.
Again thanks to everyone!!
About a year ago I saw a pallet of Craftsman floor jacks on sale at O'Reilly's. The picture on the box was EXACTLY the same as my Harbor Freight jack.
Last edited by Cliff Harris; Jul 14, 2013 at 08:48 PM. Reason: Incorrectly stated "Sears" instead of "Craftsman".
