LT-4 with black smoke??
Old Jul 7, 2013 | 01:23 PM
radar502's Avatar
radar502
Default LT-4 with black smoke??
My 96 LT-4 was sitting for 60 days ( Have too many can't drive them all,this one needs new home ) and got in and black smoke , ran it for a little wile I guess a little better..Ran great when last drove it ??? Something stuck ..Help... thanks...
Old Jul 7, 2013 | 05:13 PM
pkincy's Avatar
pkincy
Do you smell raw fuel? Blue is generally oil, white is generally water (think head gasket), and black is normally fuel being dumped (think injector stuck open).
Old Jul 7, 2013 | 07:30 PM
larryfs's Avatar
larryfs
60 days is nothing. They sit on the car lot for months.
Black is fuel.
Blue is oil.
Old Jul 7, 2013 | 07:59 PM
radar502's Avatar
radar502
I put some techron in it and drove it 50 miles runs better but a low speed still ruff ,I can wind it up and it goes like a rocket .. I guess a big tune up is in the cards... thanks...
Old Jul 7, 2013 | 08:01 PM
radar502's Avatar
radar502
PS I did smell raw gas at first now just ruff a low speed...
Old Jul 8, 2013 | 10:23 AM
pavlova1000's Avatar
pavlova1000
Could be weak ignition or fouled 02 sensors. Pull the plugs, black soot on one or two would indicate leaking injector. If all are sooty, look to the O2 sensors and/or ignition.
Old Jul 8, 2013 | 10:28 AM
pavlova1000
Also by hooking a fuel pressure gauge to the shrader valve you can watch for leak down through the injectors.
Old Jul 8, 2013 | 10:38 AM
radar502's Avatar
radar502
Thanks ,I am going to pull out a few plugs and take a look.. I runs way better after the techron so that's telling me something in the fuel sys. I thinking injector , will just haul after around 40 mph ,I had it on 130 MPH and was ready for more ? About the only thing left Org. are the injectors all else is new .It's been tuned WOT ,I realy don't know what that has to do with it ,I don't how that works on the front ones?,the back O2s are not even installed ..I let it sit for a wile I guess not good ..Thanks..
Old Jul 8, 2013 | 10:57 AM
pavlova1000
Let me know what you figure out!
Old Jul 8, 2013 | 11:00 AM
radar502's Avatar
radar502
Will do..
Old Jul 8, 2013 | 11:05 AM
pcolt94's Avatar
pcolt94
Is the digital temperature gauge reading correctly. If it is not, then check the temperature sensor in the water pump (wires, connections, sensor, etc).
Old Jul 8, 2013 | 11:14 AM
radar502's Avatar
radar502
Looks ok, I checked it out ,both gauges seem to be the same temp and as far as I can tell .. I thinking fuel sys.. but in same Techron runs a little better and no black smoke on the rear bumber as befor..Just ruff at low speed..I am going to check the injectors out they have 150,000 miles opn them ,I have never cleaned them ? I guess now is a good time for that..
Old Jul 8, 2013 | 12:09 PM
Kevin Woods's Avatar
Kevin Woods
......the back O2s are not even installed......
OK.....this can be a problem UNLESS you had the rear O2's tuned out via the PCM.
Did you?
.....I am going to check the injectors out they have 150,000 miles opn them ,I have never cleaned them ? I guess now is a good time for that..
It may be best to have them reconditioned versus you just trying to "clean" them. There should be somebody out in your area that does this service.
Here in San Antonio, there is "Fuel Injection Specialties" that does this work; turnaround = a couple days or so....... If you can't get them serviced in Houston, you could send your to FIS.....
http://www.fuelinjection.com/injector.html
KW
Old Jul 8, 2013 | 12:18 PM
radar502's Avatar
radar502
Did you?
It may be best to have them refurbished versus you just trying to "clean" them. There should be somebody out in your area that does this service.
KW
The O2s were turned off my the PCM and been running for 20,00 miles no prob..I'm in Houston I see a place that can rebuild them here..It's time if that is the prop. or not.. No cat LT-4..
Old Jul 11, 2013 | 02:04 PM
pavlova1000
Did you get it figured out?
Old Jul 11, 2013 | 03:42 PM
radar502's Avatar
radar502
Thanks for asking. Not yet, I am right now cleaning out a place to work on it . The garage is full I have to move vets around to have a place to work on them and get some out of the way ,Late this aftermoon or first thing in the morning start looking.. First thing is pull a plug or two take a look them pulling all the injectors and clean check if all working then clean throttle body check wires .It runs good for about a mile then runs bad up to about 50 mph then hauls butt ??? Should take about a day or two to check it all out ... If all looks good I will have to call my tuner and sak about the O2s ,don't have a clue what WOT does to the O2s ,I know the back ones or not installed ,I hopeing this will be easy to find ...RIGHT.... All but the injectors are new the injectors are ORG...OPIT new ,wires ETC... ..Thanks for asking...
Old Jul 11, 2013 | 05:24 PM
pcolt94's Avatar
pcolt94
If I were diagnosing my car, I would take all engine readings with my Tech 1 and compare the readings to a base line or what is a proper measurement would be. Then that might give you a direction if anything is way out of tolerance. Sometimes a Tech 1 helps and sometimes is doesn't. But I understand to do this a Tech 1 or similar scanner need to be available and a knowledge of using it is required.
Guessing and trial and error can be time consuming especially on some of these kind of symptoms.
To LT-4 with black smoke??
Old Jul 11, 2013 | 11:15 PM
pavlova1000
Look at your o2 readings. Tech 1 is for obd 1. I thought you had a 96 obd 2 so you would need a tech2. Could be you run fine until closed loop. If it starts fine and then goes to hell it makes sense that you have a sensor malfunctioning. It would not be a problem at more throttle because you're engine isn't drowning in its own pudding.
Old Jul 12, 2013 | 08:37 AM
radar502's Avatar
radar502
Thanks for the input , I don't have a scanner or tech 1 or 2 and it is a 96 LT-4 ..It needs to be gone over anyway ,It's been a wile ,the injectors need to be looked at, just sitting around is not good for it a few things need to be cleaned ..After I check a few things out and it's still not right I go get it scanned ,there is a shop in town ( Houston ) that can check it.. One of the O2s may be bad ...
Old Jul 12, 2013 | 10:29 AM
pcolt94's Avatar
pcolt94
Actually the Tech 1 will do OBD2 for a 96 if you have the mass storage cartage which has the proper software. You also need an additional cable to run the tests.
(Tech 1 and Tech 1A uses different interface cables).
If you have the individual cartages (modules) like 88 to 95, then you will not be able to test a 96 car.
