Having a bad feeling! 383 Build!
This is the block the way it came back from the machine shop.
This is the block assembled. 6in rods 385 mine is a 040 bore.
This is a picture of Will installing cam bearings. But you can see where the block was machined for clearance. BTW they used a machine to clearance and not a hand grinder.
Hope you get this straightened out without a lot of expense.
not sure this is what you want to hear.
this would be a more permanent fix.
good welder would be able to fix that right up.
would trust that more than putty.
just an idea for you to consider
Jim G
Jim G
Jim G
if the shop doesn't step up, and owner can't afford a new block, a patch job might be the only alternative.
if this has to go to court, it might be cheaper to fix what he has and get the car running.
not saying its right. some time right a wrong don't enter into what cards we are dealt.
Jim G
Once again you are absolutely right. I went in this morning and had another heater discussion with the owner of this shop. Then I went over all the parts that they ordered. ( I ordered the majority myself) It turns out the guy responsible for the work on my car is the moron making the mistakes. I got all the numbers off the parts they ordered and double checked everything at home. It turns out the idiot ordered a centerforce clutch that is only rated for 500 ft/lbs at the crank. (DF03900) and he ordered a aluminum flywheel that cost me 400.00. Obviously this isnt going to work considering the car should be up in the 700+ chp/torque range. I am at a damn loss for words and totally stressed out. I just want my car home. I am going to seek legal advice . I have all my text messages saved and I took plenty of pictures with the owner holding the flashlight in the freeze plug hole for me so you could see the light threw the holes they made...Also a few of you have mentioned using a die grinder. It definitely looks that way but in reality they used a mill with some cheap bit in it. You would think they would have better skills that that.
Anyway this is a lesson learned for me and I hope these guys dont get to do this to someone else. I will be contacting the better business bureau along with my attorney. thanks for all the replies guys!
I'd call this a costly, but nevertheless wonderful "save".
Jim G
Jim G
As for the other options mentioned here... Welding cast iron, espc a BIG complex casting like an engine block or cyl head is very specalized work. To do it right, it cost alot of $$$. The only place I have ever trusted do that kind of work for me was Windy City Engineering... like I said it was very expensive and I only spent the $$$ considering the value of a few very rare sets of # matching Ford SCJ cyl heads and one windowed Boss 429 block....
That repair cost does not compute considering the value of a replacement GENII LTX block.
Considering the cost of machine work to bore, hone, line hone, deck and assemble a short block - I wouldn't trust Joe Blow the local welder to braze it up or lay a bead of nickle rod on it and then have it crack as soon as the block gets up to operating temp and leak coolant into the oil....
No way in hell you should be stuck with this f'd up block. A replacement GEN II LTX should be fairly easy to find. I buy them all the time for $75-$150. It'll most likely be a 2 bolt main (F or B Body) but 4 bolt caps are easy to install for a competent machine shop.
Will
Will
Jim G
Also, While I was at the shop the last time today I saw that they ordered cat back magna flow exhaust when I already have American Racing headers with the X-pipe which connects to any axle back exhaust.They have ordered the majority off all the parts wrong. I believe the only parts that are correct are the ones I ordered!
I am going to get all of my stuff and my money back first thing in the morning. I am actually staying up until 7:30 am so I can be there with the truck and trailer when the doors open at 8 Am. Eagle forged rotating assembly $1800.00
Centerforce Clutch 700.00
Canton Oil pan 370.00
Oil Pump $ 44.00
Oil pump drive $ 25.00
Cat Back Exhaust $ 800.00
Flywheel $ 390.00
Shipping $ 150.00
Procharger Repair $ 450.00
Intake Gaskets $ 24.00
Timing Chain set $ 120.00
A/C Delete Kit $ 150.00
Comp Cam $ 300.00
Severe duty pushrods $ 150.00
ARP Main Studs $ 120.00
ARP Head Studs $ 200.00
Head Gaskets $ 160.00
Bore and Hone $ 140.00
Line Bore $ 135.00
Clean Block $ 55.00
Deck Block $ 105.00
R&I Engine with Blower $ 1000.00
Assemble engine and blueprint, $ 1600.00
Clearance block
Port match intake & exhaust $ 250.00
Balance rotating assy & weld up crank $ 375.00
Finish polish crank to size $ 100.00
Water Pump $ 150.00
Fuel Injectors $ 400.00
Brake Clean $ 25.00
Oil Royal purple break in and regular oil $ 100.00
Coolant $ 35.00
Oil Cooler $ 160.00
Block Sealer and hardblock $ 125.00
Spark Plugs $ 36.00
Fuel Filter $ 15.00
Install Exhaust (approximate) $ 550.00
Dyno Tuning (approximate) $1200.00-1400.00
Total (without extras) approximate $ 12700.00 – $13000.00
Extras
Meth Injection Basic kit $ 650.00
Programmable kit (PWM nozzles) Add $ 400.00
Install Meth basic kit $ 350.00
Install programmable kit & Program Add $ 350.00
Cut Outs with turn downs $260.00 ea $ 520.00
Install Cutouts and wire $250.00
Do you guys know anyone who charges 1,600 to assemble a engine or tighten some exhaust clamps up for 550? or how bout 1800 for an internally balanced rotating assembly and then add 375 for balancing it.
BTW, is the car so it can be rolled around? Are you bringing help to push it into the trailer? Are you prepared to load the block etc.? This shop may be less then helpful assisting you.
It blew up. But Will had friends do the machine work to my new, old block. They decked it, bored it, installed splayed main caps, align bored it, and balanced the rotating assy. Will then inspected everything, and did the assembly of the motor.Its just a shame to see someone getting took like they tried to take you.
Again, good luck and keep us posted on how it turns out.
