8192 Data
Old Jul 9, 2013 | 08:33 PM
dlee425's Avatar
dlee425
Default 8192 Data
Does anyone know if the 1228109 chip will do 8192 data ?
There was a cutoff somewere on 160 and 160/8192..
Old Jul 10, 2013 | 02:13 AM
Cliff Harris's Avatar
Cliff Harris
The 1227165 ECMs (starting in 1986) will output at 8192 baud.
You need the correct interface that supports the switch from 160 to 8192. That means the correct cable/software or tester.
Old Jul 10, 2013 | 07:22 AM
dlee425's Avatar
dlee425
The problem iam finding is some of the roms will not support 8192. The interface on ts says GM160 on the lower screen. Just seeing if its the Rom or maybe a problem with interface. I did find this quote below:
First of all, yes, the cable is fully capable of doing it. The 10k resistor (that we've talked about before) is what sends a TPI '165 ECM equipped Corvette in to 8192 baud mode.
However, 86 is a weird year. Early 86 Corvettes had a program in their chip which did *not* support 8192 baud - they were 160 only. Later 86 Corvettes have no problem running 8192. If his is an "early" 86, then it very likely will not work if he's still using the stock program - it's not the cable, it's the ECM program. The unfortunate thing is that I do not know the "cutoff point" between these two. This is just based on my experience with 86 Corvette owners (I've been through this before).
Old Jul 10, 2013 | 06:49 PM
dlee425's Avatar
dlee425
My Chip has a label on it AANM. I have the 5.7 w/ alum heads and 3.07 gear. I think this might be the problem with the 8192 baud.. Any thoughts..
Old Jul 11, 2013 | 04:36 AM
Cliff Harris
In my '86 code (BUA) there is a handshake test that the ECM does with the tester. It expects to see some hexadecimal bytes from the tester before it switches to 8192 mode. This is in addition to the 10K resistor.
My car was built in December 1985 and has cast iron heads, so it's an early '86.
BUA is auto trans and 3.07 gears. There are two versions, 9340 and 1728. I don't recall which one I've got. There are some variations in some of the parameters.
Old Jul 11, 2013 | 04:34 PM
dlee425's Avatar
dlee425
Mine should have it then. Its has the 1228109 chip in it. Iam using TTS i might try another software program and see of it will do it.. What program are you using ?
Old Jul 12, 2013 | 02:36 AM
Cliff Harris
I use Diacom. I bought it in 2000. From what I've seen it's way overpriced compared to what's available now and Rinda has switched to boating applications. I don't think you can even buy Diacom for cars any more.
I don't recognize the 1228109 part number. Everybody I know of goes by the 3 or 4 character letter code (known as a BCC or "broadcast code"). It's visible through a hole in the MEMCAL cover on a silver label, like so:
Old Jul 12, 2013 | 05:38 AM
WVZR-1's Avatar
WVZR-1
1228109 (1736AANM) was OE for '86 and one of very few that still used the 7 digit SPO part numbering format, most all of the '86 PROMS were of the 8 digit variety. That could be maybe significant when looking at the quoted reference you make mention of. Do I know for certain? Definitely not but I only see three 7 digit options and several of the 8 digit builds.
Cliff is correct of the two versions of the BUA and oddly maybe, one is a 7 digit reference and the other an 8 digit reference:
1227944 (1728BUA) that shows to be a coupe with no cylinder head material restrictions and the 3.07 gear.
16059335 (9340BUA) that shows to also be a coupe but with cast iron (KB2) and the 3.07 gear.
It might be an interesting check if he could to see which his actually is.
Old Jul 12, 2013 | 06:15 PM
dlee425's Avatar
dlee425
So this could be the problem iam having doing 8192 and its possible with the flakey code 33.
Is there a rom i should look for to put in ?
Thanks...
Old Jul 12, 2013 | 06:48 PM
WVZR-1's Avatar
WVZR-1
Thanks...
I would see if Cliff maybe has the 9340BUA which is an 8 digit SPO and if that's the case then I could give you a list of the 8 digit numbers with PROM ID's. I guess you only need a "core" that you can both program and data-log?
Old Jul 12, 2013 | 09:18 PM
dlee425's Avatar
dlee425
I have a BUA bin file for 86 w/ alumi heads and 3.07 gear and auto. I will just need to burn a new chip. You think this one would work ?
I need to reset the fan temps anyway, and find were you delete the egr valve in the program.
Old Jul 13, 2013 | 01:59 AM
Cliff Harris
I made a list of the EPROMs that I knew about a few years ago with part numbers. I think I got the information out of the part book. Near the bottom of the page:
http://home.earthlink.net/~cliff_har...Misc/misc.html
The only way I'll find out which numeric code I have would be to pull the ECM. Too many other projects going on right now. Next one: replace oil pan gasket, timing chain, timing chain cover, water pump and minor related parts. I suspect scraping the gaskets will take a week all by itself...
Old Jul 13, 2013 | 07:38 AM
dlee425's Avatar
dlee425
Thanks for your help I will burn this BUA chip when my burner comes in and give it a try. This should giveme the 8192 data and may solve my other problem with the MAF.
Will post on Scan and Tune and see if anyone knows which pram needs to be changed to delete the egr valve..
Donnie
To 8192 Data
