LT4 Valve Covers/Chrome?
Old Jun 27, 2002 | 02:37 PM
James94LT1's Avatar
James94LT1
Default LT4 Valve Covers/Chrome?
I was thinking of maybe putting some chrome valve covers on my new
heads I am installing. Just a thought at this point. Can't decide between
the stock steathy look or show off?!? I was looking for the ones with the
red bowties in the middle. Does anyone know how much these are and
where I can find them? Also Will they work on LT4 Heads?
Thanks!
Old Jun 27, 2002 | 02:41 PM
Vvcdde's Avatar
Vvcdde
Default Re: LT4 Valve Covers/Chrome? (James94LT1)
You gotta coordinate...if you have chrome in other parts of the car, then go for the chrome covers, if not...I would stay away..just one humble mans opinion...
Old Jun 27, 2002 | 04:09 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Default Re: LT4 Valve Covers/Chrome? (Vvcdde)
http://www.sallee-chevrolet.com/Prof...ve_covers.html
Old Jun 27, 2002 | 04:37 PM
James94LT1's Avatar
James94LT1
Default Re: LT4 Valve Covers/Chrome? (PurpleC4)
Thanks Purp,
Do you know if these will clear 1.6 rollers?
Old Jun 27, 2002 | 04:54 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Sure will. I have them on my 92 Coupe. Most important is the fact that they allow the alternator to fully rotate down in front of the valve cover with just a minor grinding to the bottom/back of the alternator housing. This is a major problem with other (aftermarket) valve covers.:eek:
~ Purp
Old Jun 27, 2002 | 06:39 PM
James94LT1's Avatar
James94LT1
Thanks again! You don't happen to have any pics do you?
Old Jun 27, 2002 | 06:53 PM
STL94LT1's Avatar
STL94LT1
James, go to (sdpc2000.com) they may have the valve covers you are looking for.
Old Jun 27, 2002 | 06:54 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
I do at home (on my home computer). I will try to remember to pull them up and post them for you to see. Actually, they look great!
~ Purp
Old Jun 27, 2002 | 08:32 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
OK, here they are. Of course ~ the red bowtie will have to be painted the same color as the lettering on the fuel rail covers.... :yesnod:
~ Purp
[Modified by PurpleC4, 5:34 PM 6/27/2002]
Old Jun 27, 2002 | 08:56 PM
James94LT1's Avatar
James94LT1
Hey thanks Purp!
Those look good. My question is on the passenger side I have a tube that hooks in the side of my stockers (intake side) and goes to the T/B yours
looks a little different. Did you modify it or were the 92-93's different?
Old Jun 27, 2002 | 11:08 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
92/93 are the same. The tube is not a problem with these valve covers.
~ Purp
Old Jun 27, 2002 | 11:39 PM
96LT4SS's Avatar
96LT4SS
1st Gear
if you're looking for an economial solution for valve covers, i had mine sent to jet-hot and coated with sterling 1300, looks like polished aluminum and it only cost 65.00!! :cool:
Old Jun 28, 2002 | 01:39 AM
Patrick96LT4's Avatar
Patrick96LT4
Default Re: LT4 Valve Covers/Chrome? (96LT4SS)
Pics?
Old Jun 28, 2002 | 06:43 PM
lead_foot's Avatar
lead_foot
Hey Purp, Is the recirc hose on the passenger side a stock GM part? If so for what year vette? As James mentioned the stock LT4 (1996) has the hose coming out of the side of the valve cover not the top. It's towards the rear on the passenger side.
Thanks for any info.
Old Jun 28, 2002 | 07:32 PM
lead_foot's Avatar
lead_foot
Default Re: LT4 Valve Covers/Chrome? (lead_foot)
Another question. Does anyone know if the GM covers listed below fit the LT4? Do they clear the 1.6 RRs without modification?
141-130
GM 12497978
SBC Die Cast Polished Valve Cover (They're Here NOW! Price is in the database.)
Aluminum, Die Cast, polished valve covers, center hold down, tall (1/4" taller than stock). Includes internal oil drippers and OEM-style baffles, 8 mounting bolts, 8 stainless steel and rubber washers, 1 air breather grommet, and 1 PCV grommet. For 1987-up Gen 1 and Gen 2 engines with center hold down design. (Two covers per box.)
They're at http://www.sallee-chevrolet.com/Prof...ve_covers.html
To LT4 Valve Covers/Chrome?
