remove cat or precat?
punch out the pre cats and the main. I am a FIRM believer in giving the gov what they want. Never screw with the people that can make life difficult. As long as they SEE a cat they assume that it IS a CAT. Until you have to TEST...seeing a cat is good 'nuff.
Empty? maybe so..but it LOOKS legit.
The hot ticket for a budget upgrade is a set of LT exhaust manifolds. Go find a set of those to stick on your L98 and it is a big improvement. The port problem is resolved and things get better instantly. The LT ex manifolds fit too....just like the L98 stuff.
A State Trooper I know says the same as somebody posted above. "You may remove the equipment if inoperative but it has to be replaced with a similar part."
My VW (water cooled) actually passed the emissions testing here in Virginia without it's catalytic converter.
I was under the impression that when the EGR system is removed including the temperature sending unit the computer will give you a check engine light. Having an aftermarket exhaust system I have never had any issues with my OBD1 in my 1988 Coupe.
There are hundreds of C4's that have had their emissions equipment removed, we hear some of their problems occasionally here. Since it is YOUR Corvette you can do whatever you want to it.
I see myself as just the "temporary owner" of either of my Corvettes and I feel responsible to pass them on after my ownership and I would like to have it all working the way it was designed . I save all the parts from my cars and box them with labels so the next owner can remove my modifications and restore it to stock condition if that is what they want. I hope someday 50 years from now somebody might like driving a 1968 Corvette Roadster with a tweaked 427.
Here is some of what I found:
"You may remove an emission system or device at any time if you are replacing it with one that is specified for that vehicle and is equally effective in reducing emissions. For example, it is acceptable to replace the engine of a vehicle if:
- the replacement engine is certified by the EPA;
- the replacement engine is compatible with the vehicle chassis and all applicable emission control systems and devices are properly installed and operable; and
- the resulting vehicle is identical, with regard to all emission-related parts and engine design parameters and calibrations, to the same or a newer model year vehicle, as originally equipped.
An older engine may be installed in a newer chassis if all emission control systems and devices are connected, including the exhaust system and catalytic converter, and the resulting engine-chassis configuration conforms to the engine configuration of the model year of the chassis or newer."
Here is another very clear speaking document that describes "tampering" with a vehicles emissions system from the EPA:
https://nepis.epa.gov/Exe/tiff2png.c...5C9400062S.TIF
Take a quick look and you will probably be surprised! I know that the law is much more strict than I had previously thought.
Corvette Owners are great people and I understand the NCRS guys and I understand the modifier. You both have reasons for doing what you want to your Corvette. We should enjoy our Corvettes to the fullest but within the law (for the most part)...
I apologize if I stepped on any toes out there.
Best Regards,
Chris
