1990 corvette idling too high
Old Jul 17, 2013 | 03:50 PM
LarryShivers's Avatar
LarryShivers
Default 1990 corvette idling too high
I had an injector problem and had to replace them. Once replaced the engine ran good but it would not idle down. When cranked it goes up to around 1500 - 1800 then idles back to around 1000. Does anyone have a solution?
Old Jul 17, 2013 | 04:26 PM
AirForceOne!'s Avatar
AirForceOne!
Sounds like a vacuum leak or maybe your air idle control valve?
Was it doing this before the injectors were replaced?
http://www.ecklerscorvette.com/corve...1990-1995.html
Old Jul 17, 2013 | 04:44 PM
LarryShivers
It was idling normal before I replaced the injectors. I cannot find a vacuum leak. I did have to unplug the idle control valve when I was replacing the injectors.
Old Jul 17, 2013 | 05:18 PM
aklim's Avatar
aklim
Where did you get the injectors from? If it is from some internet source that nobody knows, it is possible they got a bad or mismatched set. Are you SURE you checked for vacuum leaks? If so check one more time. Use a propane torch on your hoses. One might be cracked.
Old Jul 17, 2013 | 10:09 PM
LarryShivers
Injectors were from Rock Auto. I'll check again for vacuum leaks. Thanks for your responses.
Old Jul 18, 2013 | 02:00 AM
Cliff Harris's Avatar
Cliff Harris
Do a minimum idle adjustment:
http://www.batee.com/corvette/dcrg/r...scuss_sim5.htm
Old Jul 20, 2013 | 09:46 AM
LarryShivers
Did not change - still idling around 1000 - 1100.
Old Jul 20, 2013 | 09:55 PM
ladystoy69's Avatar
ladystoy69
what size and type injectors did you go with?
what yr. is the vette and any mods etc?
Old Jul 20, 2013 | 10:04 PM
LarryShivers
Injectors were from Rock Auto - Standard T-Series. Part number FJ47T. 1990 stock.
Old Jul 21, 2013 | 06:54 PM
aklim's Avatar
aklim
What is your IAC count?
Old Jul 22, 2013 | 10:50 AM
LarryShivers
What count are you referring to?
Old Jul 22, 2013 | 11:14 AM
MrWillys's Avatar
MrWillys
If all you did was replace injectors they could be undersized. High idle is vacuum leak, or a lean condition. Buy a cable here:
http://www.reddevilriver.com/aldl.html
This will allow you to datalog the vehicle and observe what's going on. Look at BLM (block learn memory) counts. 128 is perfect, and 160 is lean, and 108 is rich. You can identify if you have a lean condition. Sorry, but a catalog store is not a place to buy injectors unless you know exactly what you're getting. You could borrow a good scanner and make a similar observation also. I've had nothing but trouble dealing with cars that have used these Standard products injectors.
Old Jul 22, 2013 | 11:37 AM
bob guzzy's Avatar
bob guzzy
Spray some carb cleaner or brake cleaner around the injectors and listen for a stumble, if you are getting a stumble that is the engine trying to burn the carb cleaner getting in around the injectors.
Could be the injectors are the wrong size for the holes or the donuts on the bottom of the injectors are broken letting air suck in (vac leak).
Old Jul 22, 2013 | 11:39 AM
aklim's Avatar
aklim
IAC count. If your IAC counts are low, it means your TB is opened up too much. If your counts are high, it means your TB isn't opened up enough
To 1990 corvette idling too high
