Changing fan temp switch.
Old Jul 19, 2013 | 09:57 PM
ScottMA64's Avatar
ScottMA64
Default Changing fan temp switch.
On my 86, does anyone know how much coolant loss to expect when changing the aux fan temp switch? Just not sure if a few rags are enough or will I need a pan?
Thanks!
Scott
Old Jul 19, 2013 | 10:35 PM
JackDidley's Avatar
JackDidley
Put a pan under it but Ive done it and only lost an oz. or 2. Do it cold with the radiator cap in place.
Old Jul 19, 2013 | 10:37 PM
Lucky86's Avatar
Lucky86
Have the switch near by , when you pull the old one out slap the new one in. Its not under high pressure or anything. But do it cold.
Old Jul 20, 2013 | 09:13 AM
ScottMA64's Avatar
ScottMA64
Thanks guys.
Scott
Old Aug 22, 2018 | 02:07 PM
86project's Avatar
86project
Default Aux fan temp switch
Thanks!
Scott
Hello Scott, I have an 86 as well, my rad fan comes on @ 230* and would like it to come on sooner, is this aux fan temp switch you speak of standard or an add on equipment, and can you tell me where you purchased it? If you are talking about the CTS (coolent temp sensor) or a fan relay switch I've already replaced those. Thanks in advance, Mark
Old Aug 22, 2018 | 02:32 PM
playsdixie's Avatar
playsdixie
think he's talking about his aux fan...in front of the a/c if you have one.....easier to just ground the wire through a switch to manually make it come on.....never really noticed it making any difference....my 85 doesn't run hot so it may not be of any use at all....
Old Aug 22, 2018 | 08:01 PM
TerryOlson's Avatar
TerryOlson
Dittos
To Changing fan temp switch.
