165 memcal corvette and camaro differ?
is this true info? im not asking if i can get by with other memcals but rather if these are truely differant or not.
i'm refering to the memcal not the prom chip mind you as i know that can be anything i know.
if they are truely differant does anyone have any from vettes setting around to get rid of?
ok i found this post.... HERE
and i would rather not just be close but rather it be right or as right as it can be at least. any advise?
for example i read that the calpak from corvette has some sort of knock sensor cercuit as well that the camaro doesnt, this true?
The 4, 6 and 8 cylinder MEMCALs have different connections in the resistor networks. The ECM checks those connections and the engine will not run if they are not correct (you'll get an error code 41 "cylinder select" error). That said, it is possible to modify a 6 cylinder MEMCAL to run in a 8 cylinder ECM. i have seen info on how to do this. I don't know about modifying a 4 cylinder MEMCAL.
The resistor networks determine spark and fuel in LIMP mode. The odds are quite good that you will never go into LIMP mode, so that may not be a factor for you.
Early Corvettes have an external knock sensor module (called an ESC -- Electronic Spark Control). I'm not sure what year it got incorporated into the MEMCAL. It was around 1989, I think. Some Camaro MEMCALs have knock sensors. I know there are differences in the ESC modules so there may be differences in the MEMCAL knock sensors also.
All the calibration data for fuel and spark is in the EPROM. That data varies widely even from year to year within the Corvettes so its important to get the correct EPROM for your vehicle. One thing you can do is get the correct .BIN (for binary) file for your car, program an EPROM with that data and put it in your MEMCAL.
I was working with Craig Moates on a universal resistor network PC board that would plug into a MEMCAL and allow you to put your own chip resistors on it. That was at least a year ago and as far as I know nothing ever came of it. Either it got too complex or too expensive to be practical.
Feel free to compare what I posted with other L98 files, either F or Y body and you'll see what I mean. I will recommend your base memcal be from a tpi based 7165 car. What you burn to it is your choice.
the ecm and mem-cal/calpak i had been told was from a corvette when i bought it but now after checking numbers/codes i find it is actually for a [305cid, 5.0l camaro automatic california] and my plan as you know was using it in a 85 corvette 870-165 swap.
i already know the ecm is fine and same as used in corvette for the swap and the eprom dosnt matter as it is getting changed so ya was only the rest i'm questioning.
btw when does the ecm use this limp home info? is it used like if a part fails? like unhook a sensor then it refers to limp mode? if so i can see that possibly causing some issues, im probably wrong though lol
I'm investigating that right now. There is a \LIMP signal in the ECM that connects the microcontroller, voltage regulator/supervisor and the FMD (Fuel Management Device). The mystery is which of those chips initiates LIMP mode? I have been thinking it was the FMD because it would then kill the microcontroller and take over the fuel and spark (all the fuel and spark control is done by the FMD). There is another chip that connects to the resistor networks and feeds data to the FMD. It has only 3 sensor inputs: TPS, CTS and DRP (Distributor Reference Pulses). It has only one output (INJLIMP) that goes to the FMD chip.
Bob Rauscher (of DynamicEFI fame) speculated once upon a time that the ECM would go into LIMP mode if the battery voltage got below 10 volts. I don't know how he came up with that. The fact that the \LIMP signal is connected to the voltage supervisor chip might have something to do with that. I've been meaning to test that...
A couple of days ago I found this in the '86 FSM (page 6E-7):
"FACTORY TEST MODE, BACK-UP OR 3.9K MODE
When in this mode, the ECM is operating on the fuel back-up logic and calibrated by the Calpak (back-up chip). The Calpak Part of Mem/Cal is used to control the fuel delivery if the ECM fails. This mode verifies that the back-up feature is OK. The parameters that can be read on a "SCAN" tool in this mode are not of much use for service."
When I was doing my ECM firmware investigation a few years ago I remember finding a section that looks at the voltage on pin B of the ALDL connector. It decides what to do based on that voltage. There are four possibilities: open (normal), 10K mode (diagnostic mode), 3.9K mode and shorted (ALDL mode). That says that there is some code to handle the 3.9K mode, which equals LIMP mode according to the FSM, as quoted above. I plan on looking at the code to see what else causes the ECM to call those routines.
You can go look yourself. See my web page on the ECM firmware in my car:
http://home.earthlink.net/~cliff_har...5/BUA/BUA.html
Here's a sneak preview of the code that does the voltage decoding (roughly around LC8A0):
; Check diagnostic mode status (read ALDL pin B voltage)
; open = 5.0 VDC (10K pullup)
; 10K = 2.5 VDC
; 3.9K = 1.4 VDC
; shorted = 0 VDC
; If 0.8V < diagnostic voltage < 2V, set Factory test (3.9K) mode
LDAA #$70 ; ADC Channel 7 - ALDL pin B voltage
JSR LF1BE ; Read ADC - result in A register
CMPA #100 ; 2.0 VDC
BCC LC8E2 ; IF >= 2.0 VDC (open or 10K mode), exit via Heads Up check
; ... else
CMPA #40 ; 0.8 VDC
BCS LC8E2 ; IF < 0.8 VDC (shorted), exit via Heads Up check
; ... else (0.8V < voltage < 2.0V) 3.9K mode
BSET L0047,$80 ; ? mode byte, set b7 (factory test (3.9K) mode)
BSET L0031,$04 ; FMD control byte 2, set b2 (BYPASS# high - EST enabled)
how is one to reply to all that except um wow looks like tons of knowledge in that post and sad to say most of which is way over my head but still very interesting to say the least.i am just still simply trying to learn what the data in logs are trying to tell me, data in bins mean and understand all the peramiters as i want to learn to truely understand what and why when changing stuff , not just burn a bin and call it good enough, or copy someone elses and be done(except for a starting point) but rather truely know how to tune but trying to figure out the calpak might be just a lil too advanced for me atm
anyhow i am gaining a lil knowledge slowly and been logging.. making adjustments to car timing, idle, etc and relogging just watching logs and learning some different effects of those changes atm.. slowly but i will get there.. and thanks for trying to give me vast knowledge but im afraid atm thet knowledge is kinda like filling a 2 gallon pail with 10 gallons of water lol
but ya thanks for the confidence builder.. i'm pretty sure i will get it figured out and maybe even some day put that stroker to use in something.
btw did you see in my other thread where this has a hypertech chip in it, wondering if that may be giving me some grief, but ya if you want the bin for your collection or just fun reading, i did read it off the chip and could send it. just let me know
Tuning for me is ever evolving. Seems like every 6 months, or so I change and try things different. Currently, I'm running a pretty stock AXCR (speed density) file with modified VE table for my small cam, and elevation here at 5100'. Keep digging into it and have fun with it. Get a Moates adapter with a zif socket to make changing out chips easier. The ARAP file I posted is the best of the 7165 in my opinion. See my links page on my site linked to my username for more information on the subject matter.
Cliff is right about the 108 BLM count. The ECM is taking away as much fuel as possible. Why?
as for Moates adapter with a zif socket i already have that and some chips for the 165 ecm already, i'm just learning and playing a lil on the 870 atm till i get discusted and swap and yep i will be starting with that bin when i swap to the 165.
and as for the 108 blm i am not sure atm .. but yes the ecm is totally right it is very rich burns the eyes kinda rich .. as for why i am not sure at first i was thinking injectors leaking so i pulled them , cleaned them, tested them then put them on rail and pressurized like 20mins checking for leakage and there was non but there sure was when i pulled them so who knows they still could be giving issues so plan is replace hence why i was asking about the type III's and running 2 o-rings in another thread.
the other possibility could be the stooped cam in it, i think i will find it to be too big even with my planed future mods but idk... i have read that the durration of cams and ignition timing can give false readings to the ecm and cause rich conditions but thats a streatch as to being my problem i think but again idk
personally i'm liking the (blame hypertech) for it all after finding out there chip is in it lol nice to blame someone
The spark table in a stock 85 bin should easily handle your cam. If you could add 2 more degrees at the 600 rpm range it would help, and add 50 rpm to the idle. I could build such a file for you, but I can't erase a 2732C chip.
As for the Hypertech, I've looked at their files and really wasn't impressed. They play with the spark table a bit, and modify the fan temps is about it. They coin cute little names like Stage II, and Thermomaster, and claim X HP increases. Bottomline, you won't get 40 more HP by adding a chip, and a K&N filter.
To change the fueling on an 1985 for different injectors you need to change the injector pulse width vs. load table. Scale the table by the change in injector size. Example (30-22.3)/22.3 = .3453 or 34% smaller to get an accurate starting point for the tune.
So, an example would be. injector pulse width VS load LV8 2nd line 16's value is 610 in an HLH BCC. 34% would be 610 X .66 = 402.6? And so on down the table?
i didnt stack bins or anything special as i dont really know how , i know the bin is a 16k bin(dont know how to tell size of a bin though) but not sure what size the 27sf512 chips im using are. i would assume 512k but i read lotsa strange stuff like 32k etc but i tried stacking as 32k and that didnt work, also no idea what to fill in for block size either.
is there a way to tell these things or are these things you just have to know? like 16k bin for tpi maf vs 32k for tpi sd etc etc or can these things and chip sizes be detected somehow?
To stack on a 27sf512 chip (using the tunerpro stacking tool) you would enter bin size of 4kb, chip size 64kb, and block size 32kb. You need the G3 switching adapter from moates to use stacked bins and switch between them and I am not sure how you would do that with an 870 ECM since you cannot put a G3 in a 870 ECM. Maybe someone else can add some info on that subject?
I've never done any stacking, so I would just assume you assign different Hex address's and burn to different portions of the chip, so the Moates device can switch between them.
buffer start 00000 chip start 00C00 chip end 0ffff so im assuming it is correct.
i had just read that some stack the same bin to simplify and so there sure there will be no read problems, i dont really see how that simplifies though or stops any problems.. i do see a use though if using a switcher but otherwise nope idk but ok thanks
