1986 corvette
Old Jul 31, 2013 | 01:00 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default 1986 corvette
I did a quick search on timing but couldnt find one so im sure im asking a question thats been asked a bunch.
Im setting the timing (or trying) and im having a hard time with the timing mark jumping all over the place.
I warmed up engine to operating temp and then dissconnected brown wire with black stripe. Engine changes sound. I put clamp around plug one and hooked up timing light (brand new Craftsman. I have a Snap on timing light coming today) I point light and the needle is all over the place like i never disconnected wire.
The engine is pretty new. I do have a mild cam in the engine and was wondering if thats causing the problem. The only thing thats not new is the distributor. That might be the original one from 1986 (i think) Ive had the car 13 years and dont remember changing it. Other than that the car sounds really good. I think the damper is original also.
383 stroker
dart pro heads aluminum
30 pound injectors
larger intake manifold
adjustable fpr
58mm throttle body
lingenfelter intake
racing aluminum radiator
3:54 gears
new auto tranny
Old Jul 31, 2013 | 01:41 PM
bjankuski's Avatar
bjankuski
How fast is the idle? Even though the timing connector is disconected the timing will jump up if the RPM is too fast. (Approximately above 1000 RPM) I have no idea why this happens but on my 1986 I need to make sure the idle RPM is low when setting the timing.
Old Jul 31, 2013 | 01:48 PM
PMARTINEZ92126
Its about 800 to 900 rpm. The engine has a slight lope (looping idle) so i keep it up to stop it from stalling out when i come to a quick stop. I could try and bring it down and see if that helps.
Old Jul 31, 2013 | 03:17 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Loose/worn distributor gear.
Loose/worn timing chain?
Old Aug 2, 2013 | 11:20 AM
PMARTINEZ92126
I changed timing lights to a Snap On brand and it worked perfectly. The timing mark stayed still. I wonder why the brand new Craftsman had so much trouble? Maybe i had a setting wrong or something on the Craftsman!
Old Aug 2, 2013 | 12:00 PM
MrWillys's Avatar
MrWillys
Have you modified the programming for the cam? More timing at idle and higher idle speed?
Old Aug 2, 2013 | 12:05 PM
PMARTINEZ92126
I did have the chip reprogrammed years ago but im sure its time for a redo because of porting and larger injectors etc. I would like to find someone in San Diego that does dyno tuning and can burn a chip for me. As of now im just adjusting the idle manually to about 750-800 rpm.
Old Aug 2, 2013 | 12:10 PM
MrWillys's Avatar
MrWillys
The idle is set in the programming, and while adjusting throttle blade screw may make a temporary difference the ecm will always be trying to adjust back to the programmed value. Are you setting base timing to 6 degrees?
Old Aug 2, 2013 | 12:28 PM
PMARTINEZ92126
yea it was set 6 degree before TDC. I have no idea what was programmed for idle. When i find someone to do the dyno tune i will ask what the idle is set for. Im having trouble getting the car to stay on when its cold so thats why i adjust the throttle. whens its warm its fine. I might have to check the IAC to make sure it adjusted right. i just did the tps sensor check at .54
Old Aug 3, 2013 | 03:32 AM
Cliff Harris's Avatar
Cliff Harris
There is no adjustment for the IAC. The ECM controls it.
You might want to clean it and the idle passages, though.
Old Aug 4, 2013 | 02:01 AM
PMARTINEZ92126
the throttle body is brand new. Im thinking the lid to the lingenfelter superam has a small gasket leak. I just ordered one but I guess theres a back order.
To 1986 corvette
