So A really dumb question I feel but whatever better to know than not Have a charged 96, automatic, with no blowoff valve. because it doesnt release boost like manual cars right.. lets say I installed one would it work? Like if when I stopped gas fully would it release and make noise?
On your 96', the blow off valve is plumped back into the intake track (due to the MAF sensor) so you won't get that "blow off" sound you might be thinking of.
Provide more details about your setup. I am not aware of any vendor who offers a supercharger without a blow-off/bypass valve.
You do not have to have a BOV plumbed back in. Most of the procharger BIG RED RACE VALVE (loud and awesome) are vented to the air. bleeds excess pressure and you should have one.
Alright well it is all coming out atm so I will look again if there isnt one could one be installed or is what mnstrlt1 said that it will not be the same sound as a turbo release?
If you haven't removed your parts yet you can accelerate in first gear getting the RPM's up and then let off the gas. You should here a BOV sound if one is installed. It shouldn't matter if it's recirculated or not you'll still be able to hear it. If you don't have one installed, I'd definitely get one. Depending on your boost levels will depend on what type to install. I've switched from an auto to manual and the BOV is much more noticeable on the manual. Post some pics of what you have so we can make a recommendation. I went from the small Bosch valve on a P-1SC recirculated to a D-1SC with an enclosed procharger big red race valve vented to atmosphere and love it. Since I have an inter cooler I had to get creative. So I had it welded to the inter cooler. Tucked under the shroud it's not too loud, although it sounds like a jet landing.
He has a MAF dude, the sensor (mounted in front of the blower intake) measures the air before it gets to the engine; therefore, the bypass valve/BOV (in this particular scenario) has to recirculate the air back into the intake track. This is now mine is too (96').
I'm running 12psi in my vortech V1 T-trim and I can't hear a thing. I'm running a larger vortech BOV. The same BOV was very audible on my 93'.
My 93' (speed density) had a BOV to atmos.
Also matters where you are mounting the BOV. If before the maf it will not need to be recirculated
mine makes BOV noises because it has a BOV. you have a bypass valve. if you want to vent to atmosphere, you need to relocate the MAF between your throttle body and intercooler. then you can add a atmosphere vented bypass valve and get the desired whoosh you are looking for. I find the MAF works great located on the pressure side on later lt1 cars!
Hi All ! First IC is 150% correct on MAF location - discharge side of blower better - always !!!!!!!!! The reason is centrifugal pumps (Vortech - ProCharger - etc.) are very sensitive to any kind of inlet restriction. Centrifugal pumps love to push not suck. Hence, if possible, locate the MAF on the outlet.
Next - definitions. Maybe mine but a BOV is used to relieve excess pressure/boost on the way up, not on the way down. A by-pass or surge valve is relieving pressure on the way down, hence it is vacuum actuated not boost activated. Some valves can do either. The bigger the valve the more you hear. The 'surge valve' is designed to relieve the pressure oscillations when you let off of the throttle and makes life easier on the supercharger bearings and or seal(s).
Next, as all of you above note, if the vehicle uses a MAF, and if the MAF is located prior to the surge valve then the surge valve must be plumbed such that the excess air is re-circulated. Otherwise on decel you could be adding a ton of fuel as measured by the improperly plumbed MAF/surge valve.
On the 1994 thru 1996 Vette you can switch your tune to S/D (it's already built into your PCM in case of a MAF sensor failure) with a click on the box in the tune. I much prefer the MAF tune. If interested to experiment simply unplug your MAF and the PCM will switch to S/D. Drive it and see. A code will set but no mind it. Clear code by dis-connecting battery.
BR - greg
AND - forgot to say that another reason for the surge valve on the MAF engine is w/o it the engine will 'hunt' like crazy as the air flow goes back and forth over the MAF sensor. Many LTx cars with the MAF in the headlamp cavity had this problem because the MAF saw the air flow fluctuations. The solution was either a bigger surge valve and/or relocation of some air inlet components.
Hi,
I´m installing Procharger P600B unit to my automatic 85 Corvette. I have now L98 TPI MAF engine, better cam, headers, 113 alu heads, 1.6 rockers, SLP porterd runners and plenium, 34lb EV14 injectors, 2,5" exhaust....dyno tested now 324hp.
Also I will install Aquamist HFS3 methanol / water injection system. I am planning to use 50/50% water and alcohol.
I have also all electrical gauges which needed. (fuel, boost and AFR wideband)
Next, I need help to choose right valve to my supercharger.
Is the Procharger red race valve right one?
Or the Procharger surge valve?
Hi,
Thanks,
The L-98 Procharger P-600B kit for the early C4s comes with the correct Blow OFF Valve. Use the blue hat BOV supplied with the kit and vent to atmosphere as the directions detail.
Why change something that is not broken...
Hi
Sorry, my mistake. I do not have a whole kit. Only P600B head unit and bracket. The rest of the procucts I need to buy separately.
Also I need to find good and right FMU?? Or should I go original FMU?
