C4 Tachometer
Old Aug 2, 2013 | 11:34 AM
Sterling Silver's Avatar
Sterling Silver
4th Gear
Default C4 Tachometer
My tachometer on my 1991 C4 has not worked since I bought it. I read somewhere that it may be the filter. I tried to jumper across the filter wires but somehow must have screwed up since now my "one to four" light is on all the time. Does anyone know how to 1) get the light back off 2) help me to get the tach working
Old Aug 29, 2013 | 02:12 PM
Vette_less's Avatar
Vette_less
Cruising
There is a plug under the distributor, the connector is brown in color. Check that, if thats plugged in then the tach portion of the distributor is bad or dash cluster is messed as well. My 91 is having the same problem.
Old Aug 30, 2013 | 12:08 AM
Cliff Harris's Avatar
Cliff Harris
Maybe the circuitry changed on later L98s (I doubt it), so...
The tach signal that the dashboard uses comes from the distributor cap. It's the white wire. That goes to the tach filter and then to the dashboard.
Old Aug 30, 2013 | 12:14 AM
vetteoz's Avatar
vetteoz
If you have no tacho at all, you should use a DVM to see if you have continuity on the wire from the coil (dist cap ) to the cluster connector
Then when you get it working you may find other problem common to 90/91 GM tachos
http://forums.corvetteforum.com/c4-g...ch-repair.html
Old Aug 30, 2013 | 01:31 AM
WVZR-1's Avatar
WVZR-1
Use a scanner and see if there's a tach reference available on the scanner. If it works at the ALDL then the issue isn't at the distributor. If the A/C is C68 you could also use the digital readout on the A/C control to check the RPMs. If it's a C60 car there's nothing other than using the ALDL. Without checking the FSM I believe this is the correct procedure for using the C68. I don't believe I've used it for 6 or so years. This single post should be correct:
http://forums.corvetteforum.com/1577429729-post3.html
Old Sep 6, 2013 | 09:32 AM
darigging's Avatar
darigging
7th Gear
Default tach not reading correctly
I have a 1990 the tach reads 3200 rpm at Idle and then red lines while driving Whats the problem
Old Sep 6, 2013 | 10:20 AM
WVZR-1's Avatar
WVZR-1
I saw your other post in the General Section where you don't mention the year! Your cluster main board is likely needing a repair to calibrate the tach. It should NOT be the filter! Have your car scanned from the ALDL and if that appears to be a correct reading then you've confirmed what I just mentioned. If your car has also the C68 A/C you can get the tach reading from there also. I believe the "multiplier" is 6.
See the link in post# 5
Old Sep 6, 2013 | 10:39 AM
darigging's Avatar
darigging
7th Gear
it a 1990
Old Sep 6, 2013 | 06:36 PM
vetteoz's Avatar
vetteoz
Whats the problem
Did you READ any of the informative tacho repair links posted above ?
Like the high-reading-tach-repair link in post # 4?
Old Sep 18, 2013 | 12:28 PM
Deepa's Avatar
Deepa
my 1991 tach flutters around like crazy...when i datalog on datamaster, the rpms show up correctly. It's not your tach filter...the cluster needs to be worked on. Do all of the other guages work? My oil temp guage doesnt get above 105* even though that too displays correctly when i log my car.
Old Sep 18, 2013 | 01:35 PM
darigging's Avatar
darigging
7th Gear
I was ready to start the repair but now the cluster is reading goofy, where is the best place to get a rebuilt or repair my cluster
To C4 Tachometer
