Starter replacement options
Old Aug 5, 2013 | 01:16 AM
S S0DEN's Avatar
S S0DEN
Default Starter replacement options
I wanted to wait until my rebuild in 6 months, but the starter is on her way out right now. The starter will make a hideous grinding noise every once in a while haha. I think it's the shaft not extending all the way out to catch the flywheel.
Either way, what starters have you guys replaced the OEM with? I will be rebuilding and stroking the 350 using flat tops and keeping the aluminum heads I have with a mild cam so compression will be slightly higher then stock.
I found this on Summit, but I am not sure if it will be a direct replacement... I have the 4+3 Manual Trans and will have a set of long tube headers eventually.
http://www.summitracing.com/parts/pw...mission/manual
Old Aug 5, 2013 | 07:25 AM
AirForceOne!'s Avatar
AirForceOne!
Looks like you need to find out if you have the 153 or 168 teeth on your flywheel/flexplate.
I just replaced mine with an OEM one.
Old Aug 5, 2013 | 07:34 AM
WVZR-1's Avatar
WVZR-1
1988 was the first year for the compact starter and I believe that if I had the OEM starter I'd consider a rebuild of "what I've got"! If yours is the original I can't think of a reason not to do yours vs the buy of something that's just "tossed together" and hyped by marketing.
If it's already a rebuilt piece from someone then maybe there's reason to consider something else BUT I think I'd investigate "what I've got"!
Parts should be quite inexpensive I'd think.
To Starter replacement options
