Radio Problem
Old Aug 5, 2013 | 05:42 PM
attyman1968's Avatar
attyman1968
Default Radio Problem
I have a 1990 ZR1 with the Bose gold CD/Cassette head unit. It turns on, antenna goes up. then just static. I knew it wasn't working when I purchased the car on Friday. Do y'all think its the head unit or CDM. I did check all the wires and everything is good. Thanks for the help!!! Brandon
Old Aug 5, 2013 | 08:13 PM
AirForceOne!'s Avatar
AirForceOne!
Does the CD player work? Check and see if the speakers work with the CD player first.
The Bose amps on your speakers are notorious burning out!
I had the same unit in my 1990 and I replaced it with an aftermarket unit! If you want to go that route, I can hep you!
If you want to keep it stock, you might want to refer to Dr Don, he repairs Bose radios and speakers.
http://www.doctordons.com/
