Need help starting car
Old Aug 5, 2013 | 06:05 PM
gerrico19's Avatar
gerrico19
3rd Gear
Default Need help starting car
I have a 84 Corvette. Doesn't start. So, I hooked up an external fuel pump and tap the starter and car starts.I have no gauges that work.
Old Aug 5, 2013 | 07:04 PM
kevingib's Avatar
kevingib
Have you tested the FP relay under the dash or the pump in teh tank? Could be a bad part, bad wire, bad relay -- really lots of stuff.
Do you have the FSM? IT tends to hold the keys to the kingdon when troubleshooting - best $75 I ever spent considering what a tow costs now a days.....
Old Aug 5, 2013 | 08:00 PM
gerrico19's Avatar
gerrico19
3rd Gear
[QUOTE=kevingib;1584595354]Have you tested the FP relay under the dash or the pump in teh tank? Could be a bad part, bad wire, bad relay -- really lots of stuff.
Do you have the FSM? IT tends to hold the keys to the kingdon when troubleshooting - best $75 I ever spent considering what a tow costs now a days.....[/QUOT
No power in car, no gauges, and ignition or horn excepts headlights. Engine cranks when I jump it but power inside.
Old Aug 5, 2013 | 08:11 PM
ladystoy69's Avatar
ladystoy69
seems like another perfect case of starting with the basics before even bothering to jumper and cobble it to run..
battery has a good charge and good connections (hot to starter and ground)?
you checked all the fuses?
first place we need to see the voltage is at the ignition switch, do you have power to there?
then how about power going from there with key on?
this will be enough to keep ya busy a bit because im not going to type a whole flowchart here lol
good luck
Old Aug 6, 2013 | 02:04 AM
vetteoz's Avatar
vetteoz
So as we are not very good mind readers on here and ESP doesn't work well over the interweb , how about some history on the car ?
Was it starting and running normally ( ever??? ) before this problem?
Have you made any recent changes ; installed / removed something ?
What has been done to it , is it new to you ,etc etc , ........
At present ,as ladystoy69 states you don't have a "Corvette" specific problem ; you have a generic no start problem .
Google "no start engine" and do the basic spark/ fuel tests 1st
Old Aug 6, 2013 | 06:33 PM
gerrico19's Avatar
gerrico19
3rd Gear
Ok.. Car is new to me. Told it was the theft deterrent is activated. Bought car and didn't run. Have ignition keys but no door keys, have headlights and taillights, no dashboard lights. I got an external fuel pump and hooked it up and jumped the starter and car started. Good battery. I have checked everything that can be checked.
Old Aug 6, 2013 | 07:08 PM
MrWillys's Avatar
MrWillys
It is my understanding the 84 has a security similar to this:
http://www.scotthansen.net/85ycarvats.pdf
Old Aug 6, 2013 | 07:09 PM
ladystoy69's Avatar
ladystoy69
left out the part that you had to turn the key to run as well, but ok that tells that you are getting power to the ignition switch(if you needed key on) so yes it is kinda sounding like a vats problem except for a couple important things...
1. 84 had no vats
2. vats would only stop starter and fuel not dash and all interior power
again check the things i posted in my last reply
Old Aug 6, 2013 | 07:10 PM
vetteoz's Avatar
vetteoz
Told it was the theft deterrent is activated. Have no door keys,
Theft deterrent system is operated by switches in the door turned by your missing keys
http://forums.corvetteforum.com/c4-t...help-find.html
Quick fix would be to bypass the Starter Interrupt Relay so you can crank the engine with the key
I got an external fuel pump and car started.
So pull the fuel pump out,
http://forums.corvetteforum.com/c4-t...s-of-pics.html
hotwire it to see if it works , check if it has 12V at the pump connector ( only for 2 seconds ) when the key 1st turned on
Old Aug 6, 2013 | 07:13 PM
ladystoy69's Avatar
ladystoy69
ahh so there is a vats sorta speak, my bad i stand corrected sorry
why does my 85 not have that ? was it an option?
Old Aug 6, 2013 | 07:36 PM
MrWillys's Avatar
MrWillys
I had this argument with a friend who has an 85. If you click on the link I posted you can see his response. I'm pretty sure you have it unless yours is an anomaly.
Old Aug 6, 2013 | 07:51 PM
vetteoz's Avatar
vetteoz
The Starter Interrupt Relay was part of the '84-'85 theft deterrent system ; if the relay was bypassed as I noted above
then you probably wouldn't know.
Old Aug 6, 2013 | 09:05 PM
ladystoy69's Avatar
ladystoy69
lol at the response
well i guess if you and vetteoz say it does then probably does, hmm something else to find and investicate, not that i want it as i have full keyless/remote start/paging alarm already even has perimiter detection.. i just need to find it now to feed my need to know hahaha
Old Aug 7, 2013 | 03:33 AM
Cliff Harris's Avatar
Cliff Harris
VATS was first used in 1986. Prior to that the starter relay was controlled by the TDS (Theft Deterrent System). That's the one that is turned off by unlocking the door with the key.
It also honks the horn if the door is opened without using the key to unlock it. You can make this happen by arming the alarm and then opening the car from the inside. I did it once when I didn't want to dig my keys out of my pocket and I had the window down about 4" because it was a very hot day. I reached in over the window and hit the door unlock button. Honk. Honk. Honk...
I don't know about other years, but on my car the horn will honk if you lock the door but don't close it. You have about 45 seconds to close the door after arming the alarm or it will start honking.
To Need help starting car
