Replace 896 Fog Lights with H11
Old Aug 6, 2013 | 10:58 AM
Finalatom's Avatar
Finalatom
Default Replace 896 Fog Lights with H11
I did a search and didn't find any info on this subject. I have a 1996 corvette coupe. I want to replace my 896 fog light bulbs with LEDs. The site I was going to buy them through does not have a direct replacement for 896. I saw a cross reference list that says H11 can be used in its place. Has anyone on the forum used H11s in place of the 896? If so, how did they fit/work?
Old Aug 6, 2013 | 04:13 PM
JimGnitecki's Avatar
JimGnitecki
Are you talking about a plug-in LED orca wire-in? I'd be interested in a plug n play LED as I never use the fog lights! LED strips would really improve daytime visibility.
Jim G
Old Aug 6, 2013 | 04:27 PM
TorchTarga94's Avatar
TorchTarga94
Subscribed. Tried HIDs in the fogs and wasnt impressed. Light scatter everywhere.
Old Aug 6, 2013 | 08:48 PM
Finalatom's Avatar
Finalatom
Yes direct plug and play. Has anyone used H11s in place of 896s?
Old Aug 6, 2013 | 09:09 PM
JimGnitecki
Do you mean something like this:
http://www.carid.com/universal-bulbs...s-3046793.html
or do you mean an LED STRIP that plugs into the foglight bulb socket?
Jim G
Old Aug 6, 2013 | 11:29 PM
Finalatom's Avatar
Finalatom
Yes like the one in the link. Is the H11 a direct replacement fit for the 896?
Old Aug 9, 2013 | 10:55 AM
Rastan's Avatar
Rastan
try this.http://www.lbfun.com/warehouse/tech_...g%20Lights.pdf
Old Aug 9, 2013 | 12:49 PM
Finalatom's Avatar
Finalatom
Thanks Rastan
Old Aug 10, 2013 | 08:56 AM
TorchTarga94
That link is for earlier C4s. Will the 885 bulb fit our later C4s? I'm not sure why the article says the later c4 has this upgrade from the factory. The stock 896 bulbs do absolutely nothing. I'd be interested in trying the 885s with a 15A fuse if the bulb fits properly. Also interested in the H11 still.
Old Aug 10, 2013 | 10:27 AM
Finalatom's Avatar
Finalatom
The article was good for info about how the 896s are wired even though the bulbs mentioned are not the same. My fogs turn off when the high beams are on.
I ordered a pair of H11s off Amazon for $5 for the pair with free shipping just to try them. For $5 I can't co wrong. I'll post how they fit and work once I get them next weekend.
Old Aug 10, 2013 | 12:36 PM
TorchTarga94
Cool deal look forward to hearing the results. I was in Walmart this morning and looked at the H11 bulbs. They are slightly bigger than the 896s. Looks like the same connection though.
Old Aug 11, 2013 | 03:55 PM
1993C4LT1's Avatar
1993C4LT1
LED fog lights will not Illuminate the road. They are just to have that HID look. I have 5K HID fogs and I'm happy with them.
Old Aug 11, 2013 | 05:50 PM
Finalatom's Avatar
Finalatom
1993C4Lt1, I'm coming to that same conclusion. Do the 5K HIDs require anything special with regard to the electrical system? I'm thinking of yellow LEDs for parking lights, and brighter fogs, that are more to the blue spectrum to have the LED look but still light up the road.
Old Aug 11, 2013 | 07:03 PM
1993C4LT1's Avatar
1993C4LT1
No, it's a simple plug and play kit. Easy to install. If you want that blue look, get the 6k fogs.
Old Aug 11, 2013 | 07:18 PM
Finalatom's Avatar
Finalatom
So, what is the kit??? Specifics please
Old Aug 11, 2013 | 11:27 PM
1993C4LT1's Avatar
1993C4LT1
I bought mine from corvettehid
Or you can buy from corvettemods.
Old Aug 11, 2013 | 11:44 PM
TorchTarga94
Two bulbs and two ballasts. You plug your stock connector into the ballast, and you plug the HID bulb into the ballast. Very simple. Definitely brighter.
Just know that all of these HID kits you can buy, whether it be from a vendor or flea bay, is made in China. I started having problems where I kept blowing fuses. One of the ballasts were shorted causing my tail lamp fuse to blow. I got replacement ballasts and then I kept having problems with my battery draining after the car sat. It would also cause my passive keyless entry light to flash on and off whenever I turned my fogs on or off.
This may not happen to you, but just be forewarned that cheap components can cause goofy things to happen.
I have since returned my fogs back to stock after going through a few vendors and a couple sets of HID kits. Now I have Hella e code head lamps with Philips Xtreme power +80 bulbs and couldn't be happier. The low beams are excellent and the high beams are extraordinary. Also a very sharp and defined cutoff.
To Replace 896 Fog Lights with H11
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Those LED bulbs for your fog, and brake lights are a waste. Do the HID kit, there are tons of threads about those projects.
Old Aug 11, 2013 | 11:55 PM
Finalatom's Avatar
Finalatom
PLRX thanks. I'm getting that opinion from a lot of people
Old Oct 28, 2013 | 03:45 AM
TorchTarga94
Just curious if you ever got the H11 halogen bulbs to work in place of the 896's?
