Which injectors do I need?
Old Aug 17, 2013 | 09:19 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Originally Posted by WW7
Call Jon at "Fuel injecter connection" . He will let you know exactly what size injector you need so there's no guessing, but like mentioned above , you will need to know about how much HP your motor produces.........WW
Exactly, Jon will know what you need by the description of your engine. I am also running 30 lb. Bosch III's in my 383. The Bosch III can work all the way up to 8 bar, mine are set at Jon's recommended 3 bar. (3 bar = 43.5,,, 8 bar = 118 lbs.)
Old Aug 20, 2013 | 05:52 AM
vette 15x's Avatar
vette 15x
Default injectors
30 POUNDERS are OK.But not all injectors are the same.A stock multec defi will not take high pressures.60 PSI MAX.Now bosch is a pintle type will handle a lot more.
