Which injectors do I need?
Old Aug 10, 2013 | 05:16 PM
Strick's Avatar
Strick
Default Which injectors do I need?
I'm building a LT1 383 with the GM hot cam kit and the LT4 top end (heads, intake, etc.) What size injectors do you guys suggest?
Old Aug 11, 2013 | 12:17 AM
drive it's Avatar
drive it
http://www.fuelinjectorconnection.co...alculator.html
Old Aug 11, 2013 | 12:57 AM
vette 15x's Avatar
vette 15x
Default injectors
How much horse power ?Stock will handle 450 HP.No need to spend money unless have to.
Old Aug 11, 2013 | 06:56 AM
WW7's Avatar
WW7
Call Jon at "Fuel injecter connection" . He will let you know exactly what size injector you need so there's no guessing, but like mentioned above , you will need to know about how much HP your motor produces.........WW
Old Aug 11, 2013 | 09:53 AM
383vett's Avatar
383vett
My 383 ran fine with 30lb injectors.
Old Aug 14, 2013 | 10:34 AM
Kevin Woods's Avatar
Kevin Woods
You can do up to 36LBs but I would make an effort to find and go with 30LB'ers......
However.....if you have persisting doubt, get with whoever is gonna do your tune for their recommendation .
KW
Old Aug 14, 2013 | 12:44 PM
aklim's Avatar
aklim
I'm curious. Why did you choose 30lb? For 450HP, wouldn't it be running 95% duty cycle from the calculations?
Old Aug 14, 2013 | 01:13 PM
383vett's Avatar
383vett
I ran with 30lb injectors running low 11s for years while bracket racing. I do my own tuning with an ACCEL dfi and had plenty of fuel and never a failed injector. I probably made over 1000 runs over 5 years with this setup shifting at 6300 rpms. I now run a 406 using 36lb injectors shifting at 6700 rpms and again , still have plenty of fuel. I record all my runs with a wideband. I'm not as much concerned with duty cycles and such as much as what works.
Old Aug 14, 2013 | 02:46 PM
aklim's Avatar
aklim
Good to know. I got 42 because the chart said I needed that much. Thought it was a little much but if I was making 410 at the wheels, I thought 500 was a realistic number at the crank so I needed 42pph. Good info in case I do something else.
Old Aug 14, 2013 | 02:54 PM
MrWillys's Avatar
MrWillys
Although a wideband is best you can still read your narrow for .860 at wot. I'd be curious to see what your afr is under load?
Old Aug 14, 2013 | 04:03 PM
aklim's Avatar
aklim
Now that you mention it, I am too. I'll check one of these days when I have both the time and clear road and the weather cooperates.
Old Aug 14, 2013 | 07:40 PM
383vett's Avatar
383vett
42 should be fine if you're worried about it. As long as the motor is tuned correctly you'll be ok.
Old Aug 15, 2013 | 12:16 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Doesn't take batch fire on each revolution into consideration. Not looking up your year -- and IF that applies, I won't make any further statement.
IIRC, Only 96 had sequential fire, right?
A couple years back, there was a big discussion (including Jon) about CorkVette making 500rwhp on 24lb injectors. I finally figured out they're firing once per engine revolution version once per intake cycle.
I wouldn't be surprised if the stock injectors were big enough. Fuel pressure is a consideration too...since more pressure will make the injector effectively bigger.
Old Aug 15, 2013 | 07:35 AM
aklim's Avatar
aklim
I'm a 91. Pressure is stock. Not sure how much more you can expand the injector with fuel pressure myself. How much pressure can the injector take before it runs into the point of diminishing returns?
Old Aug 15, 2013 | 10:29 AM
383vett's Avatar
383vett
A lot. Increasing fuel pressure, increasing pulse width, and increasing injector size are all ways of increasing fuel supply to your motor. Ideally you should have a way to monitor and tune your motor to it's specifec parameters.
Old Aug 15, 2013 | 11:21 AM
aklim's Avatar
aklim
I guess what I didn't know is when you take a stock injector at 43.5 psi, can you crank just the pressure up a lot? How much till it is excessive? Also, how much more fuel will it give when you crank it to that pressure? I would suppose if you are maxed out in pulse width and if you can increase the pressure you can get more fuel into the combustion chamber. What I don't know is what is the max pressure the injector will accommodate and, if you will, how much "larger" will it make that injector. So if you have a 24pph injector at 43.5psi and now you crank the pressure up to say 60psi, does that 24pph injector act like say a 30pph injector or larger?
I didn't tune it myself. I kinda leave that to professionals that have a good reputation and have a dyno or data log.
Old Aug 15, 2013 | 11:56 AM
MrWillys's Avatar
MrWillys
Play with this and you'll get your answer:
http://www.csgnetwork.com/fiflowcalc.html
I don't know about a maximum pressure, but do know that newer cars are running higher pressures. Also, GM used many different pressures throughout the years of the C4 depending on the injector they used.
To Which injectors do I need?
Old Aug 15, 2013 | 08:19 PM
Red Rocket's Avatar
Red Rocket
Had the LT4 28 lb injectors in my original 396 LT1 set up. Fuel pressure at 50 worked best. Have 42 lb injectors now.
Old Aug 16, 2013 | 11:41 PM
vette 15x's Avatar
vette 15x
Default injectors
Like I said before stock injectors are or should be enough on batch fire sysems,but LT1S have sequential systems as far as I know.All this will effect FR.But remember if you are driving on street,the larger injectors,do run dirtier at idle,as PCM has trouble controlling pulse width at low numbers.Adjusting injector size is also nessasary in programming ,as pcm needs to know what size injectors it has to make fuel calcuations.Also O2 switching and frequency of injector pulse will effect richness at idle and fuel economy.
Old Aug 17, 2013 | 08:37 AM
Vett1990's Avatar
Vett1990
I built my L98 383 this past winter and decided on 30LBS injectors which work great. A few important things I discovered on the dyno was the pressure setting and fuel pump delivery.
I spent over four hours on the dyno, we started with our FP at 45 psi, the engine performed OK but not what we expected. Increased the FP to 50 PSI and the engine came to life with a 35 Hp increase.
As we continued to make runs on the dyno we noticed a lose of performance at max rpm and load. We had 50 psi at idle and no load with vac line removed, at max rpm and load we started to loose performance and Hp. Now what? come to find out our FP would drop to about 46-48 psi under load because my stock fuel pump couldn't keep up with the demand. New in tank pump, now were off to the races!
In short, 30 PSI injectors work great, make sure your FP stays constant while under load. I love the 383!
