Coolant loss
Old Jun 30, 2002 | 12:14 PM
Breezy's Avatar
Breezy
Default Coolant loss
I've been noticing for a couple of months that I have a slight coolant loss but since most of my trips are 50 miles or less it didn't seem too bad. Yesterday I did a 200 mile day and ended up adding coolant twice for a total of about 1/2 gallon. There are no signs of leaks anywhere. Over the last year I have replaced all hoses. I even replaced the water pump when I changed my opti. Last month I replaced the surge tank when I noticed a slight drip near the radiator cap. I realize it is possible I have a head gasket leak but I see no signs of steam coming out the tailpipe.
Any ideas or suggestions? TIA
Old Jun 30, 2002 | 12:28 PM
VetteNoob's Avatar
VetteNoob
Default Re: Coolant loss (Breezy)
Not quite sure on the LT1s, but by L98 had a small leak that would burn off before it actually dripped anywhere. it was slow enough that on a hot engine (pressured radiator) the engine block would evaporate the leak before it hit the ground. Do you smell coolant? What does your motor oil look like? Does it look somewhat like caramel? If it does, then it is getting into the block. Good luck.
BTW, Hayward, nice place. Ive got family in Castro Valley.
Old Jun 30, 2002 | 12:35 PM
Ender85's Avatar
Ender85
Default Re: Coolant loss (VetteNoob)
Have you replaced your radiator cap?
Old Jun 30, 2002 | 12:37 PM
Breezy's Avatar
Breezy
There is no coolant smell and the oil looks clean and clear.
BTW- Castro Valley is much nicer than Hayward. IMHO
[Modified by Breezy, 12:13 PM 6/30/2002]
Old Jun 30, 2002 | 12:38 PM
Breezy's Avatar
Breezy
Default Re: Coolant loss (marthpodi)
Yes. New cap came with the surge tank. thanks
Old Jun 30, 2002 | 02:06 PM
flubuyu2's Avatar
flubuyu2
Hey when you find out please let me us now what it is ! I've got a '93 with the same problems ,after changing everything as you(not head gaskets yet ) I was told here that mine might be the connecter tube in the back of the heads(four rubber washers)and this was confirmed when talking to our friend jeff k @ Chevy;buuuut yours has no visible dripping?? well mine too so if you've figured it out ,let me know where to begin.
Thanx,
Black 'm6 '93
Old Jun 30, 2002 | 02:09 PM
xzvs's Avatar
xzvs
ok pressure test your cooling system when the engine is dead cold. run the tester up to 18-20 psi. With a cold engine everything is contracted and hard to find leaks will show up. If the pressure is dropping and you see no leaks --take a close look at the heater core (you will smell coolant with the heater on ) Also, while it doesn't sound like you have a head gasket prob --if the pressure is dropping and you can't find your leak anywhere it may be going into the cyl. Very dangerous situation then. If there is more than a little bit of coolant in the cyl it will hydrolock and either bend or spit a rod. S0, if you have a def leak and you cant find it by looking thoroughly --pull the spark plugs before you crank it.
Old Jun 30, 2002 | 02:45 PM
89 Bob L's Avatar
89 Bob L
xvzs
I agree wi xvzs. How many miles are on the car. Pressure test the system with the engine cold. Check: the inside passenger side of the car, the engine, the radiator area, underneath the engine, and around the water pump. If you don't see it immediately, put the car in a cool shaded place, pressurize the system and come back an hour or so later. The leak should be evident. If there is not visible leak. pull the plugs, you may notice a slight discoloration of one of the plugs, an indication of a bad head gasket. Le me know how you made out.
Old Jun 30, 2002 | 04:11 PM
Breezy's Avatar
Breezy
Default Re: Coolant loss (89 Bob L)
Thanks guys. Looks like my next step will be a pressure check.
I'll keep you posted via this thread. (82K miles)
:chevy
[Modified by Breezy, 12:12 PM 6/30/2002]
[Modified by Breezy, 12:14 PM 6/30/2002]
Old Jul 3, 2002 | 12:51 PM
Breezy's Avatar
Breezy
Just wanted to update you guys since you took the time to respond to my problem.
I went to a mechanic I trust yesterday and we did the pressure test.
It held pressure very well indicating no leaks.
He seemed quite sure that I don't have a head gasket leak and suggested that I pull the radiator and have it boiled out.
I didn't pull the plugs to check them yet but I will do that first.
Thanks for the advice.
Mike
Old Jul 3, 2002 | 01:12 PM
guywade's Avatar
guywade
thers just no way that you can loose 1/2 gallons and not have a leak problem . i believe it's in the head gasket onto the exhaust side, thats would make the coolant vaporise and show no leaks, can you smell coolant out the tail pipe, did you leave the pressure test for a long time, ? the 1/2 gallon sure went somewhere , , i truly wouln't think a clogged radiator would do it, that would make the engine temps run high, do you have that ?? :cheers:
Old Jul 3, 2002 | 01:14 PM
scorp508's Avatar
scorp508
My upper radiator hose was dripping at the radiator when things got heated up. I guess the hose was expanding. I had to tighten the clamp down on it. I never knew it until I had the hood open one day after I got home from work (50 mile drive) preparing to do some work on the car. Just happened to notice it.
Old Jul 3, 2002 | 08:30 PM
Breezy's Avatar
Breezy
Default Re: Coolant loss (guywade)
guywade- I agree with you. That 1/2 gal had to go somewhere. I really don't think I have a leak that is burning off like that. I'm sure that with all the time I've spent with my head under the hood that I would smell it and as per my earlier post, I don't smell any coming out the exhaust either. I don't mean to say that it can't be happening but .....???
As far as overheating goes, not at all. On the 200 mile trip where I lost the 1/2 I reached as high as 230 in some backed up traffic but that is normal for my car and the aux. fan kicks in around there and brings it back down real fast. I didn't pull the plugs yet but they only have about 1k miles on them and might not tell me anything.
Anyway thanks for all the thoughts.
Mike
:cheers:
Old Jul 3, 2002 | 10:26 PM
ittlfly's Avatar
ittlfly
If all else fails, you can put a dye into the coolant and that will point the way if the leak is external. You can get it from Cromwell tools if your parts house doesn't have it.
To Coolant loss
