Starting problems
Old Jul 3, 2002 | 08:43 PM
Ericthewolf's Avatar
Ericthewolf
Default Starting problems
Seems if I turn my key on and wait for 5 seconds or so then start my car it starts right away but if I just put the key in and turn it, it takes 2-3 tries to start>>?? why? I posted before and thought it was just having trouble starting when it was cold but was working fine when the engine was warm but it seems if I do as above it starts??
Old Jul 3, 2002 | 10:44 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
Default Re: Starting problems (Ericthewolf)
Sounds like your fuel pressure may not be holding and you have to wait for the system to prime. I would check the pressure to see if it is bleeding off quickly. Good luck.
