Cat Removal Question
Old Jun 30, 2002 | 01:22 PM
shamvette's Avatar
shamvette
Default Cat Removal Question
I am ready to drop my cat but before I can do this there is a circular 'clamp' that covers the pipe out of the cat that connects to the pipe ASM. Does this clamp need to be reused?? The only way it looks like I'll be able to get it off is by cutting..... Is there (another) special tool I'll need to remove this clamp??
Thanks!
Old Jun 30, 2002 | 08:32 PM
shamvette's Avatar
shamvette
Default Re: Cat Removal Question (shamvette)
Somebody HAS to know something about this :confused:
Old Jul 4, 2002 | 08:15 PM
Skippy Stone's Avatar
Skippy Stone
If you can get a screw driver in there, you can pry it open. Sometimes you can reuse them sometimes you can't. What are you putting in place of the cat? Different cat?
Old Jul 6, 2002 | 10:19 AM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default Re: Cat Removal Question (Skippy Stone)
I used TWO screwdrivers,one on each sidetwisting in opposite
directions. Then used sidecut pliers to clamp it back together,but
not to hard!!
Matt
To Cat Removal Question
