vacuum lines
Old Aug 17, 2013 | 07:56 PM
bj9064696vette's Avatar
bj9064696vette
Cruising
Default vacuum lines
I jave a 96 vette and have some vacuum lines off of the front left of the engine can anyone help
Old Aug 18, 2013 | 04:21 AM
Cliff Harris's Avatar
Cliff Harris
There should be a label in the engine compartment somewhere that shows the vacuum connections. Mine is on the radiator shroud.
Old Aug 18, 2013 | 09:13 AM
TJM's Avatar
TJM
First off fill out your details for all I know your the guy down the street and I can walk down there and help?? We do that.
Second a picture is worth 10,000 words.
Most likely, the lines are Fuel Tank Evaporation lines but more details needed.
Old Aug 18, 2013 | 09:35 AM
bj9064696vette
Cruising
Not down the street. But i will get some pics on here. But there is one line on the front left and one on the middle left.
Old Aug 18, 2013 | 09:42 AM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
Pictures are really need before advice can be given. Post them as soon as you can.
Do you have a FSM?
Old Aug 18, 2013 | 09:46 AM
bj9064696vette
Cruising
Am working so it will be tomorrow
Old Aug 18, 2013 | 09:47 AM
bj9064696vette
Cruising
Ok what is FSM
Old Aug 18, 2013 | 10:01 AM
Old Ben's Avatar
Old Ben
Ok what is FSM
FSM is the Factory Service Manual. There is one for each specific year and it contains repair/testing procedures along with parts location drawings. If you will be doing your own work then you should definately have one.
It can be bought in either book form or on a disk. They are available on ebay and again they are year specific so you will need to make sure it is for the '96.
Old Aug 18, 2013 | 10:03 AM
bj9064696vette
Cruising
Yes it is a 96 and am doing it myself and I don't have one but I will get one thanks. Does it have vacuum line diagram
Old Aug 18, 2013 | 10:57 AM
Old Ben's Avatar
Old Ben
It has diagrams, drawings and exploded views. It also has diagonistic procedures. Just make sure you get the one specifically for your year. There will be two books to the set and each is over an inch thick. It is not the Preliminary OEM book nor the small Haynes, or similar, books.
If you google "96 corvette factory service manual" you will see the book set for $129.00 and below it the CD for $25.81 plus shipping. Check them out and see which you prefer. I think both have customer service numbers for questions before you buy.
To vacuum lines
