87-earlier E-Brake question
Old Aug 17, 2013 | 10:28 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default 87-earlier E-Brake question
I am curious as to where the spacer seen in this picture goes when this is installed on the knuckle..
THANKS
Old Aug 17, 2013 | 11:45 PM
-=Jeff=-'s Avatar
-=Jeff=-
Also if anyone has a diagram of all the parts that would be great as well
Old Aug 18, 2013 | 02:37 AM
cgantner5150's Avatar
cgantner5150
I just looked through my 86 FSM - no spacer listed or shown anywhere. Sorry I couldn't help.
An observation - my rear calipers don't look anything like those. What calipers are they?
Old Aug 18, 2013 | 03:12 AM
WVZR-1's Avatar
WVZR-1
I believe what I'd do is using a knuckle, hub, spindle assembly from a later C4 do some builds on the bench experimenting with spacer placement. I'm guessing you're anticipating/assuming that they're an appropriate fit for the rear of a later C4. I've an assembly your welcome to for the shipping "to use" but I would think there should be the same "local" to you. The one I would let you use is part of a pair that I understand are from a '93 35K car. I'd maybe consider the sale of the assemblies if after the build you wanted to do a pair and just swap the built assemblies to the car.
Old Aug 18, 2013 | 05:28 AM
Cliff Harris's Avatar
Cliff Harris
Here ya go:
http://parts.nalleygmc.com/showAssem...rimLevel=14233
You can zoom in on the image for a better look.
Old Aug 18, 2013 | 07:29 AM
WVZR-1's Avatar
WVZR-1
Here's a "real life" early e-brake and you can compare your casting numbers and assembly to see if it's actually just a package for "early C4" and not something that is adaptable to the later C4. After looking at the image in this link it seems very likely that it is what maybe you have:
http://www.ebay.com/itm/1987-C4-CORV...941#vi-content
It would seem that the placement that you have for it in your snapshot is likely correct and it was used to position the rotor for the caliper. You could bolt any rear hub to the brake assembly to confirm since all of the rear hubs are the same. One hub 3 bolts and you have your answer in 30 minutes.
Old Aug 18, 2013 | 10:47 PM
-=Jeff=-'s Avatar
-=Jeff=-
Thanks for the info.. I think if I can install the 87 style E-brake on my 90 then it may actually hold the car.. not sure why the OEM brake does not hold it.. But I don't really want to deal with it any more, not sure what else to try to fix it
To 87-earlier E-Brake question
