cant get the darn things loose, rounding off nuts WITH flair wrench. Need to have tranny pulled by tomorrow (auto). have everything pulled but converter and bell housing bolts. can I cut the hard line , will it be easy to replace them or can I use a rubber hose to ite the two cut ends together>?
thanks
If you have to cut them, a fitting with compression rings works well for a splice. My C3 had rubber line up next to the radiator from the factory and they worked. I never liked them though and replaced them 2 or 3 times over a 14 year period.
Removal I guess would depend on your intentions for the car. I believe there are kits now for pre-bent replacements, if you cut intending a splice of any kind I'd want to do it where there's least possible conflict with exhaust, I'd try to make sure I could slip off the old flare nuts and just use new flare nuts slipped on the old tube and the braided line sounds more appropriate than the compression union.
I did have a friend though that did a dry fit with a compression union and when he was happy with the fit he epoxied the ferrules to the steel hard line and used a length of heat-shrink over it to protect it. I said "hide" and of course he argued that. It was actually a pretty damned good looking repair. Slip the heat-shrink over the line and when you're convinced it's leak free then just use a shrink tool to seal the deal.
If you have the cash, you might want to check out "Jiffy Tights" line too. http://motorsports.jiffy-tite.com/# They are quick disconnect, leak proof, and nice looking. h
..... Use a tubing cutter ... no metal fragments like you would get with a hacksaw ... and stagger the cuts about 3-4 inches apart ... that way you won't have to figure out which was connected where AND the compression fittings wont be attempting to occupy the same space when you put it back together ...
Great advice right there.
I have splices in my lines from removing the trans and having to cut the line to get a seized radiator fitting out. The compression fittings cost around $5 from the parts store. I have zero leaks years later. It's not under high pressure.
As far as complete new lines, you will never get them in without removing the engine first, I tried.
