1987 corvette front shock question
Old Aug 18, 2013 | 08:59 PM
Dagcolpat's Avatar
Dagcolpat
Cruising
Default 1987 corvette front shock question
Hey guys...i am getting a clunk/popping noise in front car. I was going over and tightening what bolts i could and went to top of the front shocks. Here is the question, while trying to tight nut on shock stud, should the whole upper half of the shock spin? I can spin it by hand with car on ground (not jacked)....newbie so sorry if stupid question. Any info is appreciated. Thanks!!!
Old Aug 18, 2013 | 09:29 PM
vetteoz's Avatar
vetteoz
Yes
There are two flats at the top of the shock shaft ( above the thread ) you hold with a wrench to prevent the shaft from turning
while you play with the nut
Old Aug 18, 2013 | 09:51 PM
xrav22's Avatar
xrav22
It will turn but it should not be loose in any way.
To 1987 corvette front shock question
